Question about Kitchen Appliances - Others
Vitantonio waffle iron handle just broke - Kitchen Appliances - Others
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
  • 758 Answers
SOURCE: vitantonio waffle maker
It sounds as if the iron isn't cooking at a high enough temperature. I'd try turning the iron to the highest setting, first (the thermostat may not be giving a correct reading, keeping the temp too low), before considering getting a new iron. The good news, though, is that a new waffle will only set you back about $20
Hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on May 05, 2008
swimfan8
  • 6 Answers
SOURCE: The handle on our 13124 Bella Cucina waffle iron
I had the same problem, so I contacted their customer service at (866) 832-4843.
I was informed they don't replace that part anymore.
Sorry!
Posted on Mar 16, 2009
SOURCE: waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
Posted on Mar 21, 2009
  • 492 Answers
SOURCE: waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
Posted on Apr 30, 2009
Once the waffle is cooked how do you open the iron?
You need to spray oil on the waffle iron top and bottom before you put the batter in so it doesn't stick.
When it's cooked (steam mostly stops coming out), just lift the top off, and use a fork to lift your waffle out.
Aug 27, 2015 | Kitchen Appliances - Others
Vitantonio waffle maker
have you open your waffle? if you already open it, check if theres a cut to the wires of you your waffle or check if there is a lost tread on something. thanks!
May 05, 2008 | The Home Marketplace 70047 Waffle Maker
I have a model 269C toastmaster waffle Baker.. and need to replace the right handle which has a broke leg and is unstable ... other wise it's new... never been used
You can often find good replacement parts for waffle irons on eBay using your make and model # in the search box. Or buy another cheap used one in the same model and rob the parts from it.
Mar 07, 2011 | Toastmaster Kitchen Appliances - Others
HA636-02 handle broke. Is it replaceable? Where can I get the part?
Replacement handles are not availble, fro bella cucina waffle makers, ( they are too CHEEP to provice replacement parts) they want your to buy a NEW waffle maker.
Feb 06, 2011 | Bella Cucina 13124 Waffle Maker
Screws that hold bottom and top together have come out - appears that plastic that they screw into has melted
I repaired the broken "clamshell" of my Waring Pro WMK300 Professional Belgium Waffle Maker by replacing the original screws with a pair of (black metal) #8 x 1.125 inch flat-head machine screws and anti-vibration lock-nuts. These nuts have a nylon insert to prevent loosening. The assembly is now strong enough to pick up by the handle.
I drilled into the original plastic pits to create through-holes. I chose screws just long enough to fill the anti-vibration lock-nuts without protruding. You will need to hold each nut with a wrench or pliers while turning the screw into the nylon of the nut. Tighten just until the waffle iron assembly is snug, then another 1/8 turn. The torque should increase only during this last step.
The nuts are visible when I flip the iron, but I don't mind - they just remind me that the iron is now stronger than factory design.
Feb 23, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle Iron Sticking...HELP
Try using 2 Tablespoons of oil in your recipe.
Mar 21, 2009 | Kitchen Appliances - Others
The handle on our 13124 Bella Cucina waffle iron broke off. Where can I buy a replacement handle?
Sorry!
Mar 03, 2009 | Bella Cucina 13124 Waffle Maker
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
Kitchen Appliances - Others Logo
77 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
