Question about KitchenAid Washing Machines
Kitchenaid stylemaster 622783
Manual
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: KitchenAid Stylemaster 622784 cleaning the fabric
Hi
Thanks for using FixYa. Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2009
Testimonial: "Thanks for the help! However, I can't seem to get the dispenser off. It rotates freely, but won't pull off. Suggestions?"
Jahn27
  • 1554 Answers
SOURCE: kitchenaid stylemaster 622784 will not
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Manually activate the lid switch by pushing it down with an insulated tool such a screwdriver. Replace the lid switch to address the problem if the machine still doesn't spin; otherwise it is possibly loose and only needs to re-tightened.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Sep 04, 2011
Who you use for repair kitchenaid
Manuals and Literature - KitchenAid
www.kitchenaid.com/.../OCManualsLiteratureSearchResultVi...
KitchenAid352228 product - Owners Manuals (19) ... KBFS22ECMS01.pdf - Spanish ( 1,400.13KB ); MGD3100DW1.pdf ( 6,206.93KB ); KSRS27QGBL01.pdf ( 561.29KB ) ...
Free KitchenAid Refrigerator User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kitchen Appliance KitchenAid
Products 1 - 50 of 1070 - Find owners guides and pdf support documentation for blenders, coffee makers, juicers and more. ... KitchenAid Refrigerator Manual.
KitchenAid Refrigerator Manuals ' ManualOwl.com
https://www.manualowl.com/c/KitchenAid/Refrigerator/Manuals
KitchenAid Refrigerator manuals, user guides and free downloadable PDF ...Refrigerator manuals covering 282 models available for immediate free PDF download...... Complete KitchenAid customer service phone numbers and contact ...
KitchenAid Refrigerator Repair Online Manual
www.appliancerepair.net/kitchenaid-refrigerator-repair.html
FREE ONLINE KitchenAid refrigerator repair manual - Diagnose and troubleshoot your KitchenAid refrigerator problem RIGHT NOW, cheaply and easily.
Dec 21, 2015 | KitchenAid Refrigerators
Where can I get a service manual?
Kitchenaid KSC24C8EYY02 Manuals
www.manualslib.com > Brands > KITCHENAID Manuals > Refrigerator
Kitchenaid KSC24C8EYY02 Pdf User Manuals. View online or download Kitchenaid KSC24C8EYY02 Installation Instructions Manual, User Instructions.
Sep 11, 2015 | KitchenAid KSC24C8EYY
Were do you find serial number for 1946 chevy stylemaster
1942 - 1948 Models location is under floor
mat forward of Passenger side of front seat
Sep 14, 2014 | Vehicle Parts & Accessories
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
I have a Kenmore 90 Series washing machine Stylemaster 4217017. It quit spinning tonight. How do I fix it?
Possible that the belt or the drive or the spindle assembly is the suspect. Click this link for tips to reset: Drum Reset
Jan 19, 2013 | Kenmore Washing Machines
Kitchenaid stylemaster no.622768
spin cycle does not work. Load was overloaded and refused to spin.
have emptied water, taken off lid, does not appear to be limit switch.
HELP
Feb 20, 2012 | KitchenAid Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
KitchenAid Stylemaster 622784 cleaning the fabric softener dispenser. I can't get the fabric softener apart to clean it. I don't have a manual. I bought it, used, with no manual. Suggestions?
Hi
Thanks
Rylee
Sep 07, 2009 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
77 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
