Question about GE GSS20IEM Side by Side Refrigerator
Where is defrost timer on GE GSS25JFMC refrigerator
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
Posted on May 28, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
mgprice
  • 744 Answers
SOURCE: My freezer was developing frost / not cooling very good.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Jul 29, 2009
Ge defrost timmer location gss
DEfrost timer is placed beside compression unit, behind refrigerator.
Jul 04, 2013 | Refrigerators
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
Nov 19, 2012 | GE GSS23KGS Side by Side Refrigerator
Top half of my refrigerator and freezer not as cold as it should be
Make sure there isn't anything blocking the cooling coils GE Side by Side Refrigerator GSS25JFMC Service Manual in PDF format... You can purchase a service manual from here.
Jun 26, 2017 | GE Refrigerators
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
The timer is located in the fresh food section. Open the refrigerator door and look up, its in the control housing.
You can purchase the defrost timer at the link below.
GE Defrost Timer Link
Mar 08, 2011 | GE GTS22WCP Top Freezer Refrigerator
Where would i locate defrost timer on my ge bottom freezer refrigerator
Older fridges use a defrost timer to control when the fridge goes into defrost. Yours is a newer model and uses a control module which controls all of the fridge's functions including defrost timing. It does not have a defrost timer. It cost around $150. But I would check the defrost element first. A lot of problems with the defrost are usually a burnt out heating element. Use a meter and check that the element is not electrically open.
Dec 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost heater mnot completely defrosting
unplug it and get your hair dryer remove the panel again and blow dry the entire thing untill all is melted be carefull not to over do ad not to put dryer in the freezer stand back where the water will not splash on the dryer after leave it off for 1 hour than turn back on and put setting on number 3 for 2 to 3 hours than adjust to your normal setting not higher than 5 or it will repeat problem.It is getting very well cool causing to over cool to fast.
also air spray out back side and bottom of refrigerator is always a big help
Good Luck
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Gss25jfmc side by side
Either the defrost heater (in the coil) dont work or the deefrost termostat(round thing with two wires atached to the coil) or the timer (black thing with a plug with 4 o 5 wires),it could be at the botoom front of the refrigerator,pulling the grill,or inside the fridge in thecold control box.
Mar 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 11, 2008 | GE GSS20IEM Side by Side Refrigerator
GE GSS20IEM Side by Side Refrigerator Logo
71 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
