Question about Electrical Supplies
Coleman vertex 7500
Runs but no 110 or 220 volts voltage this is 3 hers old and never started till today. It runs fine but will not put out any voltage. How do you excite the generator with a 9volt battery?
4 Suggested Answers
  • 83 Answers
SOURCE: three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Posted on Apr 02, 2009
protek480
  • 1714 Answers
SOURCE: no output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
Posted on Sep 11, 2009
SOURCE: No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Posted on Apr 02, 2010
Coleman vertex 7500
The capcitor needs checking in the end of the alternator
Oct 03, 2013 | Electrical Supplies
High voltage?
Make sure the engine RPMS are correct, and change the capacitor in the end of the alternator cover
Jul 24, 2013 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
No output voltage at all
Sep 10, 2009 | Coleman Electrical Supplies
I have a Coleman Vantage 3500 motor runs no generator output
This sound like a loss of residual magnetism in the generator. The field will need to be "flashed".This is also known as re-exciting the field of the generator.
The Coleman manual gives these steps:
1Use a 6 Volt lantern batters (dry cell) or a 12 Volt automotive battery.
2.Disconnect all loads from generator.
3. Remove the brush cover (that's the rectangular plastic cover on the end of the generator.)
4. Plug a lamp or light into the generator before starting the engine. The light will illuminlate when ?Voltage has returned.
5. Start the engine with no load connected to the generator.
6. Attach the "-" lead of the battery to the negative brush. Very briefly touch the "+" lead of the battery to the positive brush. Remove as soon as Voltage builds up.
Sep 02, 2009 | Coleman Electrical Supplies
Have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Dec 04, 2008 | Heating & Cooling
Motors fine, but no electricity - coleman 6250
pramac bought them out i just order parts today oct-15-08 call1-800-445-1805 took me awhile to get a hold of someone but she seemed to know what was going on. my guess is that the printed curciut board in the back of the generater head is bad i have had to change alot of these out.
Oct 08, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
128 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
