Question about Video Game Consoles & Games
Patch for mobackup 7.91 - Video Game Consoles & Games
How to Get Magento Patches?
Honestly, no idea what is your issue, made a google search and foud this. Any help?
How to apply Magento patch SUPEE 5344
Jun 04, 2015 | Computers & Internet
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
Can you repair sevylor bladders? if so how?
dollar store contact cement in tube., an old bike tire, cut a patch out of tire and glue the patch on glueing around hole and underneath patch. apply patch smoothly. now glue around edge of patch. and let it dry for a few days at least 24 hrs. I have patched a bic yakka and a few cheaper inflatables patches hold up and hold air. good luck.
Aug 30, 2012 | Stearns SEVYLOR Sit on Top Kayak U250
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
How do you active a patch for a game once you download it? It is an unofficial patch
This depends on the game and who made the patch.
MOST patches have what is called a self extracting installation file.
Assuming this is a windows machine.
It should have an .EXE extension. Double clicking this will cause the file to execute and install. Be careful however. Unofficial patch Screams VIRUS!!! Also keep in mind running patches will cause anyone with a different version number to be unable to connect with you in a multi-player game.
Use caution and certain of who and where this patch came from.
Oct 03, 2009 | Jade Empire Special Edition for PC
Do you download patch after patch or download the latest patch?
you can find all about games,where everything is simplified.Actually i don't know more about frequently adding of patches.please refer to the link Click here.
Hope this Helped!
Sep 06, 2009 | Video Game Consoles & Games
No connection, have checked cable connection each end without plugging it into the patch panel and it works, plug it into the patch panel nothing? Could the patch panel be faulty?
Do you mean that you tested the patch lead that connects the patch panel and the hub?
OR
The RJ45 connection at the workstation (one end) and the RJ45 connection at the patch panel (at the other end)?
If these checked out OK then the RJ45 connection at the hub could be faulty, try a different port on the hub, do you get a link light?
The LAN card in the conputer could be faulty, try another computer at the "faulty" workstation to check the network connection.
Aug 13, 2009 | Unicom Patch panel
Cant play on line
This is from the official websites support forum. Many people have had issues letting the game patch it self. Follow these instructions and you can patch it outside of the game.
Firestorm has no patches available. Tiberian Sun. however, does have one. There are three ways to patch the game.
  • You can run the auto-patch program.
    1. Click on the Start button.
    2. Select All Programs.
    3. Select the Westwood folder.
    4. Click on the game you want to update.
    5. Select Auto-Update.
    6. The game should now automatically patch.
  • If you play online, through Westwood's servers, you will receive the latest update of the game (if one is available) automatically, each time you log on.
  • If you still cannot get the patches you can retrieve them from our FTP site.
    1. Click here to access the ftp site.
    2. Click on the patch needed:
      • TS203 for Tiberian Sun
      • There is a two letter code at the end of the patch this is representative of the language of the patch.
        • ES : Spanish
        • DE : German
        • EN : English
        • FR : French
    3. Select Save in the window that pops up.
    4. In the Save As window make sure Desktop is selected in the Save in: section at the top of the window.
    5. Click Save and the patch should save to your desktop.
    6. Once it is saved to the desktop, double-click on the patch's icon to install it.
Apr 16, 2009 | EA - Electronic Arts Command & Conquer 3:...
Unlock codes
you can to apply unlock patch,but first you have to access patching. how to patch. http://www.akshayy.com/sonyericsson/tutorials/applying-patches-for-db2020-phone/
you must read carefully and apply only the patch with the same firmware of your phone firmware.If it is happen to patch not the same firmware just remove the patch. it will return to the state before you patch a wrong patch.
http://www.topsony.com/forum/patches-scripts-f36/w610i-r6bc002-40-patches-t7560.html
patch for firmware r6bc002..
there are lot of patches in there.
credit to the authors.
Do it by your own risk. i already explore a lot with my 2 w610i.
Let me know if u have question.
Jul 12, 2008 | Sony Ericsson Walkman® W610i Cellular...
Vista Patch
Simple, most unlikely solution: Try to download patch from microsoft website and install it.
Other Solution: Go to trained professional, (geeksquad or firedog), they will install it more simply and correctly.
Installation of software by them is probably like 30 bucks.
Mar 19, 2008 | Microsoft Windows Vista Ultimate Edition
Video Game Consoles & Games Logo
54 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
