Question about Onkyo Audio Players & Recorders
Connect onkyo receiver tx-nr609 to sound bar - Onkyo Audio Players & Recorders
SOURCE: Onkyo 805 sub hook up problem
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
  • 4 Answers
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Posted on Apr 17, 2009
  • 4 Answers
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Posted on Jun 17, 2009
I'm using an onkyo tx-nr609, I have a wireless speaker adaptor plugged into zone 2 on the back next to where the subwoofer plugs in, but can't seem to get any sound to come out of it. Any ideas?
Hi Chris, not all sources will play to zone 2. Only internal and analog sources. If you want to play your cable box for example you need an analog connection from the cable box to the receiver. Also, the output is very low it needs to be amplified. Thank you, Onkyo USA
Nov 15, 2016 | Onkyo Audio Players & Recorders
Can I connect an audio interface (mine is a Focusrite saffire 56) via ADAT cable. Will I receive 5.1 signal from my interface?
Hello, If by ADAT you mean optical cable then the answer is yes. Digital optical cables support up to Dolby 5.1 surround. Thanks, FJD
May 11, 2016 | Onkyo TX-NR609
Volume won't come on
Your receiver will play a single speaker under normal circumstances. Is this a new receiver?
Feb 13, 2015 | Onkyo TX-NR609
The server connection could not be established or was terminated early. PLease try again later. Trying to play Pandora on TX-NR609
You didn't say if you were using their wireless "dongle" or an ethernet connection. If ethernet try to connect another device - laptop, blu-ray or etc to see if you're getting a good modem signal. You might try re-setting the ethernet connection on your 609.
I'm assuming your audio is working, Onkyo had a lot of trouble with their HDMI cards, for some reason the defect usually took out the audio and ability to connect to the web.
Onkyo had a recall on 609s and they will repair the defect, free of charge or shipping. (In a range of serial numbers that, unfortunately, I do not know.) I took mine to a local repair shop and they told me it was recalled. It was about a year out of warranty but they fixed it.
Dec 08, 2014 | Onkyo TX-NR609
How do I get network audio
You need to buy a network adapter for your receiver. Onkyo probably sells one.
Oct 23, 2014 | Onkyo receiver TX-NR609 User Manual
My onkyo nr609 will not turn on
Hi try disconnecting all of your speakers (check speaker terminals ,all your wire,speakers as they may be cousin short)and turn on the receiver. If it shows the same problem try factory reset shown in the link below ,if that don't work then it mite be some hardware problem and you should contact your local service .Hope it helps. https://www.youtube.com/watch?v=gfJEw-VlpWY
Mar 24, 2014 | Onkyo TX-NR609
No sound from receiver to speakers
It's been several months since the original post but :
The HDMI board on several different models of Onkyo receivers were defective. There was a recall on these receivers and Onkyo might fix them for free, even if the receiver is out of warranty.
Mar 02, 2014 | Onkyo TX-NR609
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
44 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
