Question about Viking Refrigerators
Viking refrigerator vcbb363rss fan makes noise
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: My 3 year old Viking refrigerator starting making
Tubing in contact with cabinet
Drip tray vibrating
Fan hitting another part
Worn fan motor bearings
Compressor mounting grommets
worn or missing
MORE
Posted on Mar 08, 2010
  • 25 Answers
SOURCE: fan is making noise
bad sleeve bearing or worn shaft. time to replace the condenser fan motor.
Posted on Mar 11, 2010
heatman101
  • 43501 Answers
SOURCE: Viking VCBB363RSS unit is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
67r98uufdkhg
Posted on Sep 29, 2010
What is the cost of a motherboard for the Viking refrigerator model VCBB363RSS
no mother board
high volt board,low volt board, inverter board for compressor
with out looking up 200-400 each depending if can$ or us$
Jan 31, 2017 | Viking Refrigerators
Our Viking professional vcbb363rss freezer is icing up because auto defrost seems to have quit, including the freezer fan. Everyone seems to agree that it's a control board. Do where are they located?
More probable is the the defrost sensor. It is located in the evaporator section in the freezer section of the refrigerator. It will be clamped on the refrigerant return line to the compressor. The sensor closes on temperature decrease below 5 degrees and opens during the normal defrost cycle at least 2 times a day. If the sensor does not close the refrigerator stops defrosting and ice will accumulate as yours seems to be doing. Take your model number to searspartsdirect.com and find the evaporator or controls section and find your sensor. You may need to make a splice to install your new sensor to the electrical wire. some just have push on pull off connections and other have to be spliced. You may have to use a hot air gun like a hair dryer to defrost the evaporator panel to come loose to remove panel. the panels typically have several screws holding them in place and are generally easy to removel. The side normally have gaskets that need to be removed carefully with damage to be reinstalled after sensor replacement.
Hope this helps.
Oct 22, 2014 | Refrigerators
Viking refrig dbff363 fan noise in refridgerator compartment
Normal crossover fan. unless the fan is older and it can be noisy. Order new fan and it may help.
Nov 02, 2013 | Viking Refrigerators
Every so ofer the is a loud buzzing from the fan
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
May 15, 2011 | Viking Professional Series VCBB36 Bottom...
Inconsistent cooling, no ice, noisy fan motor.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 25, 2011 | Viking DFSB483 Side by Side Refrigerator
My 3 year old Viking refrigerator starting making really loud noises today...what can I do avoid a repair bill???
If the loud noises sound like a fan blade hitting ice you have a defrosting problem.
You can try unpluging the unit removing the contents then doing a manual defrost with a fan blowing into the unit for a bit over 2 hours then restarting the unit to see if the noise has ceased.
If it is a noise associated with the compressor you can try pushing it gently in it's floating mounts to try and reposition the unit so the vibration absorbers are functioning properly again.
Lastly if it is the condensor fan making noises break out the crevice tool and remove the lint from the coils. If you have pets this is very important.
Sadly if the problem repeats in less than a week after doing the above the dreaded serviceman / repair visit will be required to islolate the cause or source.
Vikings' website:
http://www.vikingrange.com/consumer/footer/contact_us.jsp?id=cat50013
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Viking 42 in Built In Professional...
Viking VCBB363RSS unit is not cooling enough. .The temp will not get cool enough, all the lights still work no problems otherwise. is there something I can do to get the temp correct.
heatman101
67r98uufdkhg
Jun 16, 2009 | Viking VCBB363L Bottom Freezer...
Noise at the top, constant
Are you saying you get the noise even when the refrigerator is not cooling? If you get the noise only when the refrigerator "runs", it is the fan as you suggest.
Apr 28, 2009 | Viking Professional VCBB363 Bottom Freezer...
Viking VCBB363RSS Fridge Orange High Temp light on
I am not sure if I have the same model, but the VIKING fridge that I purchased in Chicago is a stainless steel bottom freezer design that is horrible. I paid alot for it and it looks great on the outside - like a pretty girl that has nothing to say.....The alarm goes off constantly and tonight the freezer wasn't working! This thing is not even 5 years old and my GE fridge in the basement that I use to store drinks for the pool and things that I don't want to spoil is probably 40 years old (I got it from my parents and has NEVER been a problem). What is up VIKING? Where are your engineers??
Jul 07, 2008 | Viking VCBB363L Bottom Freezer...
Fan keeps running
freezer fan runs when freezer calls for cooling
ref fan runs when fridge calls for cooling
condenser fan up top runs with compressor
lower unit condensate fan runs with compressor
fans should not be noisy
control monitors temp and will give alarm if temp rise
please contact viking as your fridge may have a safety recall on door hinges
Jul 03, 2008 | Viking VCSB483 Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
