Question about KitchenAid Kitchen Ranges
KGCS1340P stove top -- I need burner drip pans. Source for parts, please?
I need drip pans for the burners on a Kitchen Aid stove top, KGCS1340P. Apparently the "public-spirited" manufacturer stopped making them because the stove is ten years old. There must be a source for used parts -- but where?
I'll be glad to sell you one. I have the same model and am ready to replace it with a new cooktop. I have the same KGCS1340P but can't find part under the knob.
Posted on Feb 21, 2013
SOURCE: Kenmore Electric Stove - Gourmet Edition
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Posted on Apr 06, 2009
  • 24 Answers
SOURCE: Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Posted on Jul 30, 2009
  • 10865 Answers
SOURCE: Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Posted on Oct 02, 2009
  • 969 Answers
SOURCE: Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Posted on Nov 12, 2009
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Can not get top off how to work on gas surface burners
If you provided the correct model, you should only need to remove the grates to get to the burner caps. Just lift up, on some stoves you may need to slide one of the grates a fraction of an inch away from the other if the grates are in pairs on each side. Then you can lift off the burner caps, note the caps fit onto pegs and must be positioned correctly onto the pegs when you put them back and then the sealed burner units.The drip pans also just lift out. After those parts are out you are at the main top which has no clips or screws on the parts diagram. However the flue cover may block you from just lifting it up.
I hope this helps.
(http://www.appliancepartspros.com/partsearch/model.aspx?model_id=22014&diagram_id=663880 has detailed diagrams for the parts list.)
Aug 23, 2010 | Amana ARGS7650SS Gas Kitchen Range
Need to replace the burner on my stove
TURN OFF POWER. LIFT BURNER. REMOVE DRIP PAN. BURNER SHOULD PULL UP OUT OF HOLDER. TOP LIFTS UP IN FRONT TO CLEAN & ACCESS.
Oct 21, 2009 | Whirlpool RF364 Electric Kitchen Range
Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Jun 17, 2009 | Kitchen Ranges
Sep 23, 2008 | Kitchen Ranges
Drip pan
I don't have a solution, but I am trying to figure out how to remove the sealed burner drip pans on a Thermador PRSG 364 GLS gas stove. Any suggestions?
Apr 29, 2008 | Thermador RDFS30 Dual Fuel (Electric and...
Open Questions:
Kitchen Ranges Logo
287 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
