Question about Aurora Electronics Office Equipment & Supplies
I NEED TO PURCHASE SOME SPROKETS FOR as1200AURORA
The first and last gears for the 1200x are broken. I need to know if there is a place to buy them?
  • 783 Answers
Broken cog spool - replacement
Hi you should buy new shredder because you will not get the plastic part easily and usually they do not be replace.
Jul 28, 2010 | Fellowes P57Cs Shredder
I just purchased a used roadmaster mount sx bike and can't get the front gear to smallest sproket
Here's the authoritative place for bike service (they make the tools)...
http://www.parktool.com/repair/readhowto.asp?id=75
Since cable slack is what allows the front derailleur to relax toward the small ring, it could also be poor maintenance of the shifter cable (kinks, lack of lube, rust) or a defective shifter. Give the procdure a try but just in case, look up a local Bicycle Shop. They'll fix it up fast and right.
Mar 23, 2010 | Cycling
IChain and sprocket kit Hartford Legion 125 W reg
you may find its a chinas copy of a honda 125cc so wip off the sprokets and just walk into the bike shop with them and just say "match them up mate!" dont go telling him what there off of as they just shake there heads and say iv got nothing like that? most of them are sale's shop morons? but as they say,,, monkey see's monkey go's and get's!!!! a banana as a treet helps there as well! also my bike is a copy as well and iv just changed me sprokest i droped the rear sproket teeth down by 5 teeth,,,yes thats right i did say by 5 teeth,smaller!!! it like moving first gear up into second gears place and adding a sixth gear, and i get another 10mph on top end, now i can get right across the road with out changing gear first! but it wont carry a passenger to well
Mar 07, 2010 | 2001 Hartford Legion HD-125L
Specification for Sprokets
I asked mechanic to short gear bike and I went for a 16 teeth front sproket. It gave crazy acceleration but it stole 15kms/h from the top speed. I never ride on top speed in any way, it is 270-285 kms per hour and here, we do not have any good road for this sort of speeds. I went for 16 front 44 rear sprockets combination and I like it. It is good for a fast street racings as well as for a long distance trips.
17 - 44 is standard gearing.
http://www.bitzforbikes.co.uk/Rear_Sprocket._%28high_carbon_steel_to_OEM_standard%29-ref-2515-405-224-23.html
http://www.bitzforbikes.co.uk/Front_Sprocket._%28high_carbon_steel_to_OEM_standard%29-ref-2490-405-224-23.html
Nov 21, 2009 | 1999 kawasaki ZZR 1100
Engine sproket drive shaft has sheered off
The link below will provide a diagram and part numbers for you.
http://www.babbittsonline.com/pages/parts/viewbybrand/1/Yamaha.aspx
Can't help on the dealer locations. I am in Dallas Texas USA
Top rating for the diagram? Thanks Paddy!
May 03, 2009 | 2003 Honda CR 125 R
Remington Electric Chain Saw, Model 106890-02 I need a gear replacement for the plastic gear betwen the drive gear and the gear which drives the chain.
Here is a link to the model 106890-02... http://12.153.20.74/manuals/107052-01A.pdf, I would also suggest you contact the parts department at 800-446-1446. They should be able to help you.
Mar 15, 2009 | Remington Garden
Replace the timing belt tensioner on a 1990 Nissan Sentra
The belt tensioner is located under the timing cover. It is 1 1/2 round and about 3/4 inch with a groove in the middle where a bolt is tightened. When you remove the timing cover you will see the timing belt, the camshaft sprocket and the crankshaft gear. The timing belt goes around these components.. The belt tensioner is loosened and the new timing belt is placed. The sproket also has to be replaced if it is broken. Be careful to notice the little marks that are aligned on the sproket and above the camshaft.. They can be small arrows that have to be aligned exactly the way you took them off. replace the belt and you tighten the tensioner so the belt fits snug and tighten the bolt in the middle of the belt tensioner. It is not too difficult, if you know something about mechanics. If you don't, you will be better of taking it to somebody who does know.
Oct 23, 2008 | 1990 Nissan Sentra
How to replace timing belt on 1997 kia sportage
you have 2 sprokets to worry about the top two and crank gear, the crank gear has knocht on it and index on block ( towards back of gear visible from top) place on tdc mark ( top dead center), install the timing belt on this gear first then secure it with a piece of hose or anything that fits in between housing and belt to secure belt from moving from gear) then align the right side sproket on "E" for exhaust cam at top marks on cover and sprocket, then install belt over that sprocket, finally align left side sprocket "I" for intake to the top mark and install belt not too tight or it will make noise just make sure it is firm. now to double check from left to right with you standing in front of vehicle you should have left cam sprocket with "I" for intake to the top and right sproket with "E" for exhaust to the top. having bottom gear on tdc (top dead center mark) and all marks lined up with belt installed and proper tension secured, turn engine over twice and make sure marks meet in the same place then put everything back together. ( recommend you replace both idler and tension pulleys and check water pump, replace if needed or you'll be back.- this procedure goes the same to spectra, sephia, sportage, you will not damage the engine on these vehicles if belt goes out except rio. if timing belt goes out on the rio it will need an engine, if lucky just head. recommended replacement on all is every 60k miles) goo luck tightening the power steering drive belt when you put everything back together, just use a long bar to pry and good leverage. and a second hand comes in handy.
Aug 02, 2008 | 2002 Kia Sportage
Kitparts
Check the sproket on the camshaft for broken links and the gears on the crankshaft. if all this look good, then install the timing belt. If you do remove the camshaft sproket, make sure to mark it exactly where it is at compared to the mark on the engine. Do not turn the engine at all. Everything has to be aligned exactly.
Jul 15, 2008 | 1996 Honda Prelude
Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Feb 19, 2008 | Office Equipment & Supplies
56 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
