SOURCE: makita 18v 120volt american charger to be used in australia
hi all,
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
SOURCE: I bougth reciprocating saw, model
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
SOURCE: Ihave 110 volt makita dc18rc battery charger,
I had the exact same problem. I ordered the ZNR V10 241U part from Dija Key. They are around 36 cents if you buy 10 of them. I cut the old one out and soldered the new one in. I changed the fuse over to an automotive one so the fuse is easier to obtain. I plugged it in and charger works fine.
What happens is a voltage spike either low or high gets recieved by the charger. The fuse appears to be slow blowing and does not stop the spike in time. The spike is stopped by the varactor surge supresser. In doing so, it saves the circuit board so all you have to replace is the fuse and the surge surprsser.
