Question about Bryant Evolution THERMOSTAT CONTROL SYSTXBBUID01-B VERSION 16
Thermostat replacement We have a Bryant Plus 95s Evolution running with a Trane TAYSTAT 340 thermostat, the installer said the 3-Stage 355CAV thermostat would be an extra $500 so we passed. I don't think the Trane thermostat allows the Plus 95s furnace to run efficiently? I think I should replace with a model SYSTXBBUID01-B Bryant thermostat, can I do this myself or do I need a Bryant installer?
4 Suggested Answers
flatech
  • 111 Answers
SOURCE: bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Posted on Nov 17, 2009
  • 1033 Answers
SOURCE: Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Posted on Sep 26, 2012
vschnittert
  • 38 Answers
SOURCE: I am trouble shooting a
if you are using honeywell vision pro 8000 t-stat you need an outdoor sensor program on t-stat would have to look up
Posted on Feb 19, 2013
If the fan speed is set but the ac shows off will that stop unit from running. I am not getting any air
If your temp settings our high or low it will effect the blower, Look to see what your temp settings our and also check and see if you have a fresh air blower.
Jun 02, 2014 | Bryant Evolution THERMOSTAT CONTROL...
We installed White Rodgers 1F81-261 thermostat and Bryant Plus 80T furnace about 2 yrs ago. They worked fine, until now. We tried to set the thermostat to 70F when the room is ~66F. The thermostat...
Does the display seem a little dim? If so replace the batteries. Anything else may be a furnace issue not the thermostat. Look at the furnace and see if you can view any error codes on the circuit board
Oct 31, 2013 | White Rodgers White-Rodgers 1F85RF-275...
Sep 25, 2012 | Bryant Heating & Cooling
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Changing to a digital thermostat
you cant use this thermostat . you have a trane 2 stage heatpump the hunter thermostat is made for a one stage heatpump ...if this answer helped please rate this 3 or 4 stars , this will keep me in the paid answer department
Apr 06, 2009 | Heating & Cooling
Bryant Evolution THERMOSTAT CONTROL SYSTXBBUID01-B VERSION 16 Logo
131 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
