Question about Fuji FinePix S1000FD Digital Camera
Problem downloading pictures. When camera is connected to the PC the Save Image Wizard does not come up.
Having problems downloading from Finepix S1000. When camera is connected to the computer save image wizard does not appear.
  • wiggy_42 May 18, 2009
    i have the same problem software isnt letting me get my pics i just use a card reader its alot easyer .
  • Anonymous May 25, 2009
    when trying to put oictures from camera toa fodder cannot get it to work
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Dec 25, 2012
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Finepix viewer
The simple answer for all digital camera users that have installed the supplied software is
Remove it.
Windows can do the job mach better.
The windows camera/scanner wizard asking you what to do- you tell it it does it simple huh!
Posted on Jan 15, 2008
I am trying to upload my pictures in my computer but I can't. I get a communication error.
Posted on Jun 16, 2008
dlundmark
  • 797 Answers
SOURCE: have installed fujifinepix software but
You may need to reinstall the software and drivers for your camera.
If that does not work, consider buying and using a card reader which would eliminate the need to have any drivers for the camera, because it is not necessary to connect the camera.
If you have more than one camera, it may make sense to use a card reader instead of installing software for each camera, including drivers.
Posted on Sep 24, 2008
My fine pics camera is not uploading the pictures to my pc. It's saying connect camera and turn power on. Can you please tell me what the problem is
I think you are missing a step or pushing the wrong power button.
The sequence should go like this first make sure the batteries are up to power if there is an interruption the pictures could become lost and corrupt the memory card.
Turn the camera off, connect the USB cable to the computer USB port not a hub or keyboard port.
to turn the camera on Fine Pix Viewer will start and the save Image Wizard will display follow on screen instructions to download pictures.
To disconnect make sure the indicator lamp is off then press the same button for about a second to shut the camera off THEN disconnect the camera from the computer.
You should then format the memory card to begin fresh with a clean card and allow the camera and memory card to properly communicate between each other without errors.
Here is a diagram to show you were and how to format the card.
Diagram
Have fun with your camera
Jan 17, 2011 | Fuji Finepix Z20fd Digital Camera
I'm having a very similar problem with my FinePix S1730. Loaded CD three times, restarted each time, can't get Image Capture or any other effective connection to allow me upload pics from camera to PC. PC...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 18, 2010 | Fuji FinePix Z10fd Digital Camera
Camera will not connect with PC to download pictures
Hi I am vortash .. check for damage on your download lead and around the camera plug interface .. check that the drivers are still installed and reinstall them to make sure ... if you have a sd card installed remove it as it may be lose in the socket and the camera is trying to read it and can't .. check your batteries are ok .. try it on another computer .. if all this fails sounds like the camera interface has broken constant plugging in and out can sometimes cause problems with a loose plug .. hope tthis helps Regards Vortash
May 04, 2009 | Fuji FinePix F10 Digital Camera
"SAVE WIZARD PICTURE" does not launch
yes i think u all are having problems in fuji fine pix viewer i think this peace of software is not updated with vista OS so nothing to worry just try alternate source to do this
just connect usb cable supplied with camera and connect ur camera it will show up as a removable disk in my computer open it up and download the pics if u have trouble doing it , first check if ur camera is set to PC = webcam mode and other mode icon means file transfer mode u need to select this mode from menu>setup>usb mode and then go download the pics on pc as described no need for drivers
if u have trouble i can arrange for pics to do that with a diagram
if anything else i can help
pls rate me fixya if i have fixed ur problem
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
My finepixZ20fd tells me its "in use" when trying to get pictures
Finepix are notorious for sending out CD's with camera for installing that produce problems. Would suggest visiting their website and downloading a current version from there. This may well solve all the problems you seem to be having.
Feb 06, 2009 | Fuji Finepix Z20fd Digital Camera
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
What do i do
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Need to download finepix 5.2f
Try a memory card reader that takes XD Picture Card. It saves on having to install extra software, and works with the Windows built-in Camera & Photo Wizard.
Feb 09, 2008 | Fuji FinePix S6500 Digital Camera
Finepix viewer
Remove it.
Dec 19, 2007 | Fuji FinePix 2650 Digital Camera
Finepix viewer
Nov 13, 2007 | Fuji FinePix A345 Digital Camera
Fuji FinePix S1000FD Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
