Question about GE Dryers
Replaced belt, but the new one is totally slack. Need schematic showing proper positioning of belt and motor/tensioner
  • amatwede May 18, 2009
    haven't got the solution yet. Just was asked for the third time what is the make and model number,which is GE DDE 750GBL-WH
  • amatwede May 21, 2009
    I couldn't open the picture. Could you copy and paste it in the body of the email? Thanks! Audrey Twede
  • 1,000 Answers
Attached is a picture of the idler and motor routing.
Hope this is what you were looking for. Let me know.
Regards,
Posted on May 19, 2009
  • 749 Answers
Hi can you give the the full make and model
Posted on May 18, 2009
Just put a timing belt and water pump on my 1995 dodge intrepid es 3.5 changed the tensioner pulley and new hydraulic tensioner, have had 4 new tensioners collapse can anyone tell me why they are doin
you have to release the tensioner as it is in neutral position what you need to do is push in on the tensioner and let go it should tighten the belyt as when you push it in past the lock you will see it come out quite a ways
Sep 18, 2014 | Dodge Intrepid Cars & Trucks
How to tension the BMW x5 4.4i 2003 serpentine belt
All BMWs use a spring loaded tensioner. if you are having trouble with the tension then you need to find /use the correct belt path. If you are having trouble getting the belt on the tensioner, then use a section of the old belt to tug the new belt onto the Alt. pulley.
The tensioner that is on the BMW 4.4L M104 motor is found near the idle pulley and can be locked into the slacked position with a 1/4" thick bolt that has the threads ground off also the tensioner can be operated with a 3/8 drive ratchet. Apply tension to this pulley after getting the belt wrapped around the other pulleys and then fit it over the Alt. pulley last.
May 24, 2011 | 2003 BMW 5 Series
How do i remove the timing belt tensioner without the proper tool?
TO LOOSEN THE BELT TENSIONER PULLEY ASSEMBLY, THEN POSITION A CAMSHAFT BELT ADJUSTER TOOL T74P-6254-A OR EQUIVALENT ON THE TENSION SPRING ROLL PIN AND RETRACT THE BELT TENSIONER AWAY FROM THE TIMING BELT.TIGHTEN THE ADJUSTMENT BOLT TO LOCK THE TENSIONER IN THE RETRACTED POSITION. INSTALL NEW TIMING OVER THE CRANKSHAFT SPROCKET AND THEN COUNTERCLOCKWISE OVER THE AUXILIARY AND CAMSHAFT SPROCKETS MAKING SURE THE LUGS ON THE BELT PROPERLY ENGAGE THE SPROCKET TEETH ON THE PULLEYS. BECAREFUL NOT TO ROTATE THE PULLEYS WHEN INSTALLING THE BELT.RELEASE THE TIMING BELT TENSIONER PULLEY ALLOWING THE TENSIONER TO TAKE UP THE SLACK. IF THE SPRING DOES NOT HAVE ENOUGH TENSION TO MOVE THE ROLLER AGAINST THE BELT.AND BELT HANGS LOOSE, IT MIGHT BE NECESSARY TO MANUALLY PUSH THE ROLLER AGAINST THE BELT AND TIGHTEN THE BOLT. YOU WILL NEED BELT TENSIONER TOOL OR EQUIVALENT.YOU CAN GO ON LINE INTERNET FIND THE BELT TENSIONER TOOL.SHOULD COST TOO MUCH.YOU CAN SEE IF AUTO ZONE HAS ONE TO RENT YOU.
Mar 16, 2011 | 1998 Mazda Pickup
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Serpinten belt instalation i need schematics
Possible wrong belt. Idler arm tension may be broken or weak. Make sure you have the belt properly installed.
Jan 30, 2010 | 2004 Dodge Durango
Timing marks on 1999 Ford Ranger 2.5L.
Rotate the engine so that No. 1 cylinder is at TDC on the compression stroke. Check that the timing marks are aligned on the camshaft and crankshaft pulleys. An access plug is provided in the cam belt cover so that the camshaft timing can be checked without removal of the cover or any other parts. Set the crankshaft to TDC by aligning the timing mark on the crank pulley with the TDC mark on the belt cover. Look through the access hole in the belt cover to make sure that the timing mark on the cam drive sprocket is lined up with the pointer on the inner belt cover.
  1. Loosen the alternator retaining bolts and remove the drive belt from the pulleys. Remove the water pump pulley.
  2. Loosen and position the power steering pump mounting bracket and position it aside.
  3. Remove the four timing belt outer cover retaining bolts and remove the cover. Remove the crankshaft pulley and belt guide.
  4. Loosen the belt tensioner pulley assembly, then position a camshaft belt adjuster tool (T74P-6254-A or equivalent) on the tension spring rollpin and retract the belt tensioner away from the timing belt. Tighten the adjustment bolt to lock the tensioner in the retracted position.
  5. Remove the timing belt.
To install:
  1. Install the new belt over the crankshaft sprocket and then counterclockwise over the auxiliary and camshaft sprockets, making sure the lugs on the belt properly engage the sprocket teeth on the pulleys. Be careful not to rotate the pulleys when installing the belt.
  2. Release the timing belt tensioner pulley, allowing the tensioner to take up the belt slack. If the spring does not have enough tension to move the roller against the belt (belt hangs loose), it might be necessary to manually push the roller against the belt and tighten the bolt.
The spring cannot be used to set belt tension; a wrench must be used on the tensioner assembly.
  1. Rotate the crankshaft two complete turns by hand (in the normal direction of rotation) to remove the slack from the belt, then tighten the tensioner adjustment and pivot bolts to specifications. Refer to the necessary illustrations. Make sure the belt is seated properly on the pulleys and that the timing marks are still in alignment when No. 1 cylinder is again at TDC/compression.
  2. Install the crankshaft pulley and belt guide.
  3. Install the timing belt cover.
  4. Install the water pump pulley and fan blades. Install upper radiator hose if necessary. Refill the cooling system.
  5. Position the alternator and drive belts, then adjust and tighten it to specifications.
  6. Start the engine and check the ignition timing. Adjust the timing, if necessary.
Nov 25, 2009 | 1999 Ford Ranger SuperCab
Belt came off. not broken but when i went to replace its about 4 inches to big, (slack in belt) the tension spring is not tight is there a certian route i should go with the belt,
Yes there is. The flat side should go against the drum and the tension spring pulley. The ribbed side should go against the motor pulley. The tension arm is probably out of position. You'll have to try it in different positions. Look at this diagram. It don't show how it goes but it may help. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170715&diagram_id=1353177#d1353177
Oct 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Replace belt on 2006 dodge 2500
need to find belt tensioner use wrench to take up slack from spring and use belt configuration in manual to replace belt properly
Aug 30, 2009 | 2006 Dodge Ram 2500
Timing belt
You obviously need to replace your TPS, and you may need a new belt tensioner as well. On these cars the timing belt setup is not about no 1 cylinder being top dead center. Here are the proper steps to do a timing belt on this vehicle:
To change the timing belt first place the right side of the vehicle on a jack stand and remove the right front tire. Remove the plastic cover inside the wheel well to expose the harmonic balancer. Remove the serpentine belt (standard 3/8" rachet will set in the belt tensioner to relieve tension). Remove the harmonic balancer (19mm). Place a jack under the engine on the right side of the vehicle, then remove the engine mount from the top of the fender well, (17mm deep well socket and 17mm wrench required) it is not necessary to remove the mount from the side of the engine. Remove the timing cover, (10mm) it has 2 nuts. Loosen the timing belt tensioner, (10mm) then pry it away to relieve the tension. Slide the timing belt off of the cam gear.
To position the new belt, the cam gear has a arrow on it, and the cylinder head has a small dot. Align the arrow with dot, and make sure it is aligned (the arrow must point up). The crank gear has a notch and the engine has a groove to align the notch. Again, make sure the notch and groove are aligned (they again will be up). Place the new timing belt in position around the crank gear, the water pump and belt tensioner and leave the slack at the top. Again relieve any tension from the belt tensioner, and slide the belt on to the cam gear. Place a slight bit of tension on the belt and tighten the belt tensioner. Use the 19mm bolt from the harmonic balancer and turn the engine 2 complete turns and verify that the cam gear and crank gear are in their proper positions and aligned with the dots and notches. After 2 complete turns of the engine, and verifying everything is still aligned, re-assemble in reverse. No further adjustment is necessary.
Note:There is no timing adjustment for this vehicle, and if you are not properly aligned on the cam gear and crank gear it will not run properly.
Apr 29, 2009 | 1996 Ford Escort 4 Door
Dryers Logo
43 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
