Roberts mp43 has stopped getting any DAB or FM radio reception in the last month. Both worked well before. I have tried system reset and checked Arial to no avail. Is this common issue....any suggestions
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
SOURCE: WHY CAN'T I GET AM RADIO RECEPTION - ONLY FM??
You need a seperate AM antena for your AM radio to work. If you look on the back of the system where the FM antenna is connected you will see a AM hole for an antenna. I had same problem hope it helps!
Posted on Nov 08, 2008
welcomejee
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
  • 119 Answers
SOURCE: AM reception of radio not working.
inspect antenna connection at rear gate wiring harness passthru,if this car is a wagon the rubber boot on drivers side rear gate holds the harness from getting pinched,remove this boot and inspect harness carefully you should find broken wires,repair the wires,then enjoy your a.m stations again
Posted on Jul 14, 2009
thepartspros
  • 36 Answers
SOURCE: No FM reception on factory 1996 dodge grand caravan radio
replace the attenna if that does not work the radio is the problem
Posted on Jul 16, 2009
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Apr 18, 2015 | Grundig FR200 AM/FM/SW/DAB Radio
Where can I get a replacement off-on switch for my ROBERTS ECOLOGIC 4 DAB/FM PORTABLE RADIO? The mains light is on, but the radio doesn't work and I see that this is a noted fault of this model. Is it
If you cannot get parts from the manufacturer you may end up directly connection the wires to have the radio on continuously or installing an aftermarket switch.
Feb 04, 2015 | Roberts Audio Players & Recorders
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
My Roberts MP43 Dab radio has developed a fault with its power, Display flashes & stopped working
Had same problem with a MP53 which is not a lot different.
Internal power supply had burned up due to tracking across printed circuit tracks. Tracking was caused by the horrible goo plastered around parts of the board. This goo becomes conductive with age (I wish they would not use this rubbish).
Cleaned all the goo from the board and repaired the burned tracks.
Make sure you remove all the blackened bits.
Hey presto, didn't need to replace any components.
Remove the back and the power supply comes away with it. It is well wrapped up underneath a copper plated shield so takes some effort to get in there.
A well worth repair as this unit comes in at £280.
Have fun.
Feb 26, 2012 | Audio Players & Recorders
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
Teac CR H250 plug into arial
The only thing that would damage DAB reciever is lightning hitting the arial. But all you have to do is unplug during a storm. You might get a better reception with the £100 job, but I think he was a conman!
If in doubt read the instructions!
Jan 29, 2010 | Audio Players & Recorders
Lodik dab 3006 radio
how to install a driver
Apr 30, 2008 | Computers & Internet
18 people viewed this question
 Grubhead
Grubhead
