Question about Avaya Merlin BIS 10 Corded Phone (avamerbis10)
Merlin Plus. Have two extra line buttons
Merlin Plus. Have two extra line buttons (lighted) that want to program as extensions. However, can not do it and when you press the buttons the line is silent. Any ideas?
  • Carol Harris May 22, 2009
    MFurrer,
    You were right! The other lines were programmed as outside lines. Thank you very much!
Do you have a manual? the programming code escapes me...you need to remove the lines on that phone. it wont let you program a button over a line button, so you must first remove the "Line appearances" then you should be able to.
Let me know if you need to code for the removal of line appearances....
Posted on May 18, 2009
Avaya phone system to many lights
The extra light means there is something programmed for that location. I would go into the extension programming and see what that button is set for. It could be an unused line or a feature not labeled.
May 06, 2014 | Avaya Corded Phone avaparp18d
I HAVE THE MERLIN PHONE SYSTEM 820D2 I WOULD LIKE TO SILENCE CERTAIN NUMBERS FROM RINGING. HOW DO I DO THAT?
Now that's an oldie :-) I have the instructions squirreled away right here
Here's how to program line ringing:
• go to the voice terminal whose line ringing you want to program
• slide T/P switch toward you
• touch a line button (note red lights)
• touch the button again until correct code appears:
RED ON = Ring
RED FLASH = Delayed Ring
RED OFF = No Ring
• repeat this procedure for each line
• return T/P switch to center position.
Carl
Oct 19, 2010 | AT&T Merlin Plus 820D2 KSU Phone
HOW CAN YOU USE A MERLIN MLX-10D AS A SINGLE LINE PHONE FOR A FAX MACHINE?
For the most part, the answer is "you can't". An MLX phone's extra port can operate a 3156-MFM module and derive the extra extension. There may be some conditions, like no DTMF receiver, and a few other problems.
I didn't ever sell one, but here's a link to a search http://www.google.com/search?q=3156-mfm&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
You can pick one up for as little as $50 on eBay.
Carl
May 04, 2010 | Lucent Merlin Legend MLX-10D Phone
I'm working with a Merlin 820 D2. I can't find where to Enter Administration Mode? Any assistance is greatly appreciated. Thank you
On the left side of extension 10 press the "T . P" switch down to the "P" position (programming)then press the administer or #49. (depending on the version)
Mar 25, 2010 | AT&T Merlin Plus 820D2 KSU Phone
What is the code to program a Merlin BIS-10 to have only (1) incoming line. I have a 10 button phone and it thinks there are (5) incoming lines?
Enter admin mode:
Slide switch on left (T/P) down to the "P" position.
press the intercom button above TRANSFER
dial the 2 digit extension number you want to modify
Touch the buttons to add/remove the lines.
Green light on means line is active
Green light off means line is not active
Mar 24, 2010 | Avaya Merlin BIS 10 Corded Phone...
Need to change the directory of extensions.
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Oct 26, 2009 | Lucent Merlin Legend MLX-20L Phone
How do i make a light light up on a phone
Each button is assigned by programming. It also has to have a light to light up :-)
If you're programming an extension, then press PROGRAM 99 the button and dial 1 plus the extension number. If a line, dial 0 plus the line number. All programs are ended with STORE.
Works for me.
Carl
Oct 07, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
How to hook up a fax machine to a merlin At &t phone system
Fax machine has to be connected to an analog port on your Merlin. Also you have to specified what extension it is in the programming so your Auto Attendant can forward fax calls to that extension. This is a job for a proffesional. Please hire one.
Jun 09, 2009 | AT&T Merlin Plus 820D2 KSU Phone
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
Lucent MLX-20L Extension Edit
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Avaya Merlin BIS 10 Corded Phone (avamerbis10) Logo
146 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
