Question about Pyramat Sound Rocker Gaming Chair
Arm bracket broken, where can I get a new one?
  • 60 Answers
You should find one at www.ebay.com just type in wat ur looking for and you should find it without a problem
Posted on Jul 18, 2009
I have 96 grand Cherokee i have a problem with steering arm joint hitting sway link bracket onright side when wheel turned when driving it clunks feels like wheel going to fall off no wobble at all
some part that is supposed to hold the arm and joint in place is broken
could be the end of the steering box , idler arm bearing
On the hoist inspection will reveal the area at fault
Have it inspected by an accredited specialist shop
Mar 24, 2016 | Cars & Trucks
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Windshield wiper driver's side went limp wind
THe wind doesn't just push the power arm off, it must be broken and will need be replaced, You need to check if the actuall bracket that holds the arm is broken as well. It has teeth on it which when the arm is put on it lock in place with a clip
Feb 28, 2010 | 2004 Chevrolet Cavalier
Rear wheel wobbles can't drive
That would be the rear control arm. You can provide a temporary fix using a 1 foot piece of 1" square steel tubing and 2 u-bolt brackets that fit over the broken arm (at any hardware store). Center the piece of tubing on the break inside the U of the control arm. Fasten the U bolt brackets 2" in from the ends of the square tube. This will last quite some time so you can get it replaced at a later date.
Sep 28, 2009 | 1997 Chevrolet Lumina
The wiper arm came off of my 2004 pontiac grand am. how would i put it back on?
If it's the blade arm it's generally always best to replace it new and will come with new fasteners.
If it's the assembly arm itself depending upon how it was broken off you may need to replace assembly the arm from the stem complete with new / serviceable used bracket.
Jul 27, 2009 | 2004 Pontiac Grand Am
Loose/ broken bracket axel
use a crank arm puller, somthing that looks like this5683e00.jpg, so you wont damage other parts.
May 16, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
Can't get old lower control arm off 1994 geo metro. stuck at ball joint.
remove ball stud bolts .then remove suspension arm bracket nut .remove suspension arm bracket bolts. remove rear bracket and suspension arm. torque ball stud nut 44 ft lbs torque suspension arm rear bolts 32 ft lbs.
May 05, 2009 | 1994 Geo Metro
Power window problem. engauges then disenguages
Section 01-11: Glass, Frames and Mechanisms 1997 Windstar Workshop Manual REMOVAL AND INSTALLATION Door Glass and Regulator, Power Windows Removal
svw~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel (23942) and front door inside panel sound insulator (20394). Refer to Section 01-05 .
  1. Remove inside door belt weatherstrip.
  1. Remove front door window glass (21410) as described in this section.
  1. Remove two nut and washer assemblies attaching the window regulator equalizer arm bracket (23230).
  1. Remove four rivets retaining the front door window regulator base plate to door inner panel.
  1. Remove front door window regulator (23200) and front door window channel bracket (23288) from vehicle.
  1. Working on a bench, carefully bend tab flat to remove front door window regulator arm slides from front door window channel bracket.
  1. NOTE: Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket. Make sure rubber bumper is installed properly on new front door window channel bracket, if replacement is made.
    Install new front door window regulator arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
Installation
NOTE: The front door window channel bracket and window regulator electric drive (23394) are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Door Glass and Regulator, Power Windows .
  1. Install window regulator electric drive with preassembled front door window channel bracket into vehicle. Set the regulator base plate to door inner panel using base plate locator tab as a guide.
  1. NOTE: Two 1/4-20 x 1 inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (35-44 lb-in). Equivalent metric retainers may be used.
    Install four rivets to retain front door window regulator to door inner panel.
  1. Install window regulator equalizer arm bracket.
  1. Lower front door window regulator arms to access holes in door inner panel. Install front door window glass as outlined.
  1. Install inside door belt weatherstrip.
  1. Adjust front door window glass to make sure it is properly aligned with glass run. Check window for smooth operation.
  1. Install front door trim panel and front door inside panel sound insulator. Refer to Section 01-05 .
Item Part Number Description 1 21410 Front Door Window Glass 2 23288 Front Door Window Channel Bracket 3 23394 Window Regulator Electric Drive 4 23230 Window Regulator Equalizer Arm Bracket 5 222A00 Front Door Glass Run Latch Side Retainer 6 N621906-S36 Nut and Washer 7 N800510-S36 Screw 8 23200 Front Door Window Regulator 9 W525172-S Rivet 10 W525175-S Rivet 11 — Wire Connector (Part of 14630 Wire Assembly) A — Tighten to 7-10 Nm (62-89 Lb-In)
Apr 13, 2009 | 1997 Ford Windstar
My driver side windshield wiper was frozen to the windshield. I forgot to shut them off when I went to work. When I came out and was brushing off the snow I realized that they were not off. Then the driver...
I just solved this problem last night with my '05 Impala, and ultimately the solution was what newton5083 stated above.  Yet, it may also be this (I found it online somewhere):
You have bent or broken the "park tab" on the windshield wiper motor bracket. The correct way to fix this is to remove the wiper arms, wiper linkage and wiper motor from the wiper motor bracket, and install a new bracket.
I just bent the tab back into place a couple times for our daughters 2005 Impala but it kept getting bent down again when they didn't take the time to make sure the wipers were not frozen to the windshield, or tried running the wipers to remove heavy snow on the windshield. So yesterday I fabricated a small piece of metal and bolted that to the bracket in the same place the tab stop was.
If someone wants to access this bracket and tab-
1. Use a ½ inch or 13mm socket & ratchet or wrench to remove nuts on wiper arms.
2. They may make a special tool to remove the arms, I used a screwdriver and hammer to tap bottom of the arm to wedge them apart from the spindle.
3. Two small button-looking clips hold the drivers side cowl cover in place under the windshield. These are two-piece clips, pry up the center, than the outer piece.
4. Unclip the washer hose from cowl cover, than pull out plastic cover.
5. There is a smaller plastic cover with on plastic button head holding that cover in place. Gently pry under that clip to remove that cover.
6. Now you can see the wiper trans and bracket. You should see a small tab on that bracket that looks pushed down and bent or possible a square small hole with some torn off metal where the tab broke off.
7. Remove small plastic cover over the wiper transmission and you can see a small spring-loaded arm underneath the wiper transmission assembly.
8. You need to find something to pry that tab back up so when the wipers are running that spring loaded little arm just snaps past the tab running clockwise. It's when you shut off the wipers that the wiper transmission assembly reverses rotation counter clockwise and the small spring loaded arm underneath hits that tab stop, than the wipers will go all the way down and shut off as they should.
Once that tab stop gets bent out of the way the little spring loaded arm has nothing to stop the wiper transmission assembly so it keeps traveling counter clockwise until some other stop shuts the wipers off straight up on the windshield.
There is a revised bracket part # which is supposed to be more durable, GM part #12368639. Here is a copy of the TSB which points out this problem:
Bulletin No.: 05-08-43-003A
Date: March 10, 2005
TECHNICAL
Subject:
Windshield Wipers Park in Up Position (Replace Windshield Wiper Motor Bracket)
Models:
2005 Chevrolet Impala, Monte Carlo
Supercede:
This bulletin is being revised to make a correction to the Parts Information. Please discard Corporate Bulletin Number 05-08-43-003 (Section 08-Body and Accessories).
Condition
Some customers may comment that the windshield wipers park in the out wipe (vertical) position.
Cause
This condition may be caused by a bent park tab on the windshield wiper motor bracket.
Correction
To correct this condition, replace the wiper motor bracket. It will be necessary to transfer the following parts listed below to the new bracket.
^ Wiper transmission
^ Wiper motor crank arm
^ Wiper motor
1. Remove the windshield wiper motor drive system module.
2. Remove the windshield wiper transmission from the windshield wiper motor bracket.
3. Remove the wiper motor crank arm from the windshield wiper motor.
4. Remove the windshield wiper motor from the bracket.
5. Install the windshield wiper motor to the new bracket.
6. Install the wiper motor crank arm to the windshield wiper motor.
7. Install the windshield wiper transmission to the windshield wiper motor bracket.
8. Install the windshield wiper motor drive system module.
A TSB is not a recall, if vehicle is still under warranty the dealer should be repaired for free. If not, you'll have to pay for the repairs.
Dec 10, 2008 | 2005 Chevrolet Impala
Maytag Neptune Broken Tub Support Arm
ummm yea your int market for a new washer. why cahnce epoxying a tub thats holding water doesntsound like a viable option. ( not worth the chancing the flood )
Mar 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Pyramat Sound Rocker Gaming Chair  Logo
73 people viewed this question
Top Pyramat Video Game Consoles & Games Experts
Michel Laprise Sr
Tom Chichester
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
