Question about HP Compaq nx6110 PC Laptop
Display on but lamp not on
Hello sir my laptop lamp not on but display is on
  • Frank Zhang
    Frank Zhang May 11, 2010
    you want repair by your self or just know how to deal?
  • 221 Answers
Hi, your LCD backlight has stopped working. This can either be repaired by HP, or you can replace the LCD assembly on the laptop. If you want to replace the LCD on the laptop yourself, you can find the replacement LCD online somewhere like eBay or an online parts reseller. Once you get the LCD, you can remove the old one and install the new one. It's only a few plastic panels, and about 8 screws and 1 wire.
Posted on May 18, 2009
Hello sir, I purchased ACER TravelMate 5730 Laptop before 1 and half year. upto till before 2 days that works correctly but now the problem is display is only not coming very dull display is...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 25, 2011 | Computers & Internet
Hi sir ....... when the copier ( kyocerammita 5530
Optical system (AGC) problem
1. insufficient exposure lamp luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness connections; adjust position of contact glass shading plate or clean/replace the scanner home position sensor; replace the exposure lamp or inverter pcb if needed; replace CCD unit or engine/main board if applicable
Jan 10, 2010 | Office Equipment & Supplies
Hello dear sir i have an old samsung labtop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 02, 2009 | Computers & Internet
Dear sir, when i start my Toshiba e.Studio 166 machine it can't work the LCD Screen display tools signal
yes sir it is signal your copier exproser lamp or lamp fuse is cut please chack it then solve your problem
Aug 02, 2009 | Toshiba e-STUDIO280 All-In-One Laser...
My laptop blinks several times ,want to have fix the problem
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 09, 2009 | Lenovo ThinkPad X200 Notebook
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
Error code c3300 on km-5050
Hello sir; That's exposure lamp or main board problem, my suggestion; check the exposure lamp.
Apr 03, 2009 | Kyocera Mita Office Equipment & Supplies
Have a toshiba 3560 when powered the display shows the toshiba display only and nothing else what could be the problem
Hello sir; Does that display go away within few minutes ? if not check the fusing unit, because not warm up. probably heater lamp burn out. check their continuity as well as thermo fuse.
Jan 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
LCD Display
hello dear sir madam
how are you ...i wont to tell you that can you sell the laptop for me ...i am in nigeria and i wont laptop to use... so therefore if you like to sell you can mail me ...... this is my mail jamessmith0009@mail2world.com
Aug 09, 2008 | Compaq Evo N610C Notebook
HP Compaq nx6110 PC Laptop Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
