Question about Toshiba (P000257700) Microphone
Hi, I have a QuickCam 8.0. I have removed a blue-tooth solution I was using today and want to go back to using the web cam for a mic. I have re-loaded the Logitech webacm software twice and checked that it is working. However, if I use the Windows Sound Recorder it only works if I really shout into the mic!
  • 3 Answers
Are y like....
Posted on May 18, 2009
I have a logitech Pro 9000. It works completely fine with GChat, but not for Skype. Skype complains " bad internet connection" and the video I transmit is mostly frozen. On the other hand the...
hi freeman319
you might want to try and uninstall the quickcam application. as i've researched skype is having problems with certain cams compatibility. just try and uninstall the quickcam application but not the drivers. with this you may still be able to use the quickcam with other applications.
you can uninstall it through the control panel>add remove programs
also if you are using a headset or separate mic and headset with the video call you would want to disable the mic on the quickcam
go into Device Manager and disable the microphone in the Pro 9000
ofcourse this is just some things you can try but is not guaranteed to solve your issue. please let me know if this works. thanks.
hope this helps
janc30
Feb 11, 2011 | Logitech QuickCam Pro 9000 Web Cam
Audio.
It does have a builtin mic, maybe its defective. Maybe return it.
Sep 25, 2009 | Logitech QuickCam Chat Personal Web Camera
The mic on my web cam wont work with skype..
If you have a laptop you have to change the default there as well
Audio set up Skype x Vista
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart Computer
When in skype conversation - left click on speaker icon in system tray and check Skype volume is not muted and slider is up the scale.
Aug 29, 2009 | Logitech QuickCam Communicate STX Personal...
QuickCam mic doesn't work
I read another post that said to go to Logitech itself for up-dates. This I did......downloaded all new drivers, etc. (the disc that comes with the cam must be out of date !). Then when that was done, I went back on Skype and where you do a 'voice test' I was able to this time around to "choose" my webcam - this was not coming up before at all. So in doing that it activated the mic on the webcam and all was OK. We seniors are supposed to be savvy with the forever changing world of electronic devices today! (LOL)
Feb 12, 2009 | Logitech QuickCam Messenger Web Camera
Cannot install softwear
If you are installing a webcam.Cam must be unplugged before driver install.uninstall and reinstall drivers.after install reboot.then plug cam in.os will recognize new and configure. then use your im set-up to configure for your im. in skype do this..In skype use free call set-up to set-up and configure your webcam/mic.It is fairly easy just follow the prompts.This should solve the problem .thank you for using FixYa and don't forget to vote.RICHARDM69
Jan 03, 2009 | Logitech QuickCam Chat Personal Web Camera
Mic works through the 1. USB port, CAM from the 2.
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Nov 21, 2008 | Logitech QuickCam Communicate STX Personal...
Mic trouble
I have installed software, web Cam works fine.
Down loaded SKYPE ,but when speaking with another person ,I could see them and hear them OK, but they were unable to see me although sound communication was fine. Is this a web cam setting problem or Skype problem.
Oct 12, 2008 | Logitech QuickCam for Notebooks Deluxe
Logitech QuikCam Express...Problem
instalador de camara
como tieneque bagar el listalador de camara
May 07, 2008 | Logitech QuickCam Messenger Web Camera
79 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
