Question about Xerox Phaser 6110MFP All-In-One Laser Printer
XEROX PHASER 6110 MFP REPLACE TRANSFER BELT MESSAGE
The machine displays ''Replace Transfer Belt'' machine is unresponsive. Tech support tells me they don't support the product and was manufactured by another company. They also told me that the machine wouldn't stop functioning back when I called them about the low message I couldn't reset when I called them last time. I hope somone has a solution, because I spent the money to replace the balt already.
  • aatifarbaaz Oct 17, 2009
    pls help me.xerox phaser 6110 toner refilling video
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
Posted on Oct 20, 2009
  • 2 more comments
  • acook483 Oct 20, 2009
    3. Select Tech Menu
    4. Select DataSetup
    cycle the printer.
  • juliemonreal Dec 29, 2010
    acook483,
    Thank you so much! We ordered Transfer Belt from Xerox for $250.00, installed the new belt
    We have Phaser 6110 MFP, ordered transfer belt from xerox part #023N001169. $250.00
  • 37 Answers
Replace Transfer Belt means the belt has come to end of it's life and needs replacing.
Solution: Purchase a new belt and fit into machine. The message will still be there. Call Xerox tech support and ask how to reset the transfer belt counter. It is in the "Tech Mode" of the machine....not a usual "user function", but very easy to do once you know how!
Not to be confused with: Transfer Belt Error.
Solution: Remove and reinstall belt. Switch power off/on. If problem remains it is likely that the belt is FAULTY and needs replacing.
Posted on Jun 16, 2009
Hey, I have the same printer and it is telling me to replace transfer belt, i have called xerox and printerbase but they dont sell transfer belts, where could i get one ?
Thank you
Toni
Posted on Jul 27, 2009
  • 52 Answers
This machine is simillar to Samsung CLP 300, cartridge is the same, so engine must be the same with slight differences. If you have already changed the belt and it did not reset automatically, then probably you will have to go into the printers toolbox or properties, there might be an option for that.
Posted on May 18, 2009
  • Kaviraj Ramputty May 18, 2009
    Just got this solution from another site,
    I just purchased at the Compusa closeout. I had the same transfer belt issue. I found the white connector on the back of the imaging assy. did not mate up correctly with the one on the transfer belt assy. I had to take the top cover off by removing two screws. I then had to push the connectors together. After that the machine powered up fine.
    give it a try.
What does a second transfer bias roll do
It simply drives the transfer belt which is required to lay the image down on the paper.
Depending on which Xerox product you have would depend on whether a service tech is required to replace one that has failed or whether it is a roller that can be easily replaced by a non tech saavy individual.
I hope this helps...
Mar 09, 2015 | Xerox Phaser Office Equipment & Supplies
Error code c2451 on konica business pro 550c
Your machine has a new a transfer belt and who installed it did not complete the proper procedure SO go to service mode, then counters -life-new release open the front door select the transfer belt and press start that tells the copier new transfer belt. Recommend a tech do it. Unless you know how to enetr service mode.
Jul 30, 2014 | Konica Minolta Office Equipment & Supplies
How to change unite of transfert?
Will require to open both ends of the copier. Remove the waste toner box, remove to screw on the right side these two screw are located inside the machine they hold to metal release plates if you look inside the machine you will see the belt its the shinny thing (From the right side) once done there is a handle on the transfer belt assy. that you will pull out of the machine on the left side pulling the entire transfer belt out re reinstalling new belt assy. be careful not to nick it or the DRUMS below it. Then replace the two screws. that lock the transfer belt in place. there is a fuse in the new transfer belt which the copier will blow to ensure the belt is NEW (Normal Operation) Mite recommend a Tech do it. Just my humble opinion
May 26, 2014 | Minolta CF1501 Copier
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
How can i order the transfer belt for a samsung clx3160fn
The part number is JC96-03611C. Though it might be difficult to find at a local store, you can find it online. Places like facsimile.com or printerbuddy.com stocks it.
After you remove the old one and replace it with a new one. The replace transfer belt error message will not go away until you clear the transfer belt count on your machine. To do this, you will need to follow the steps below.
3. Select Tech Menu
4. Select DataSetup
Nov 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Are you there? I have a problem with a Minolta 2200 as to the error about replace the transfer belt . Can you help
contact minolta tech support coz they will tell you how to change the transfer belt if you do not know any thing about printers get profeshinal help
Dec 23, 2008 | Minolta magicolor 2200 DP Laser Printer
We get a service call0096 on the display screen, the printer is a magicolor 4650dn
Check the 2nd transfer roller assy. This assy. located across from the transfer belt on the right side of the machine when you open that cover the sponge looking roller is the second transfer paper goes between that roller and the transfer belt in side machine, be careful of the belt, check that roller is secure, has it been replaced? If not get tech out to look at it.
Jul 02, 2008 | Minolta Office Equipment & Supplies
Xerox Phaser 6110MFP All-In-One Laser Printer Logo
7,089 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
