Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
Pillow tft led color monitor wireing - XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
Where does the blue triggered wire on a pillow tft lcd 7 inch monitor go
if you mean the 7 inch pillow car/fpv screen from ebay/amazon, the blue wire is not needed if you just use the first video connection (AV1).
However, you can use it to trigger the AV2 channel by connecting it to +12V (the same as the red cable). as soon as you connect it, the screen switches to AV2, and displays the words "Car Back" in red in the top right corner. i think its supposed to be connected to your reverse light's positive connection, so as soon as you select reverse, and the bulb is lit, it will switch to AV2, and display the feed from your rear camera. (there may be a safer way to connect it to your car, but i can't see any reason why it would not work)
As soon as you disconnect the blue cable from +12V (or change out of reverse gear), the screen will go back to AV1, and the red text will disappear.
i suppose you could connect it to your power supply via a switch, and use it to switch between two camera feeds, but the red text is annoying, its probably easier to use the remote :P
Feb 26, 2013 | Computers & Internet
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Connection diagram for pillow tft lcd color monitor
Need diagram for:
On Flap:
XF000FSCG5P
7 inch TFT LDC Digital Ca...Car Reaf View Camera Combl
Now
On Top:
12V-24V
Pillow TFT LCD color monitor
Apr 11, 2009 | Car Audio & Video
Compaq tft 5000 out of work
Your backlight probably went out and needs replaced.
Jun 18, 2007 | Compaq TFT5000 15" LCD Monitor
Car Audio & Video Logo
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
