Question about Uniden DCT756-3 Phone
My phone goes out when someone answers on the other line
I didnt start having problems with my phone until a week ago (ive had them for 2 months). Unfortunately when i make out going calls the phone goes completely silent when someone picks up or has thier answering machine/voicemail activiated. It took me 15 minutes to make a dr appointment because when someone on the other line called the phone disconnected! the problem is pretty random so sometimes it works and sometimes it doesnt. Also when the caller I.D. goes off the person i am talking to can no longer hear me, i have to hang up and call back?! Anyone with a solution to this?
SOURCE: INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Posted on Apr 18, 2008
cnavarro
  • 2460 Answers
SOURCE: one ring - noise like fax to caller, phantom call to receiver
Try unplugging all sets and call in. Do you still have a faxlike tone, like from an ALARM system or something else down the street?
Posted on Aug 21, 2009
  • 20 Answers
SOURCE: I have a Guardian home security system and comcast
Guardian has the system programmed to answer so the can program it from their office when the bill isn't paid or to disconnect the monitoring..Usally it will answer after 9 rings,it has an answer machine bypass that works like this: someone calls the house and it rings a couple times then someone else calls right back it will give the data tones..Try it call your number and let it ring a couple times then hang up and call back and you will hear the data..Call and tell them you want the remote programming disabled..
Posted on Sep 13, 2009
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
Posted on Nov 19, 2009
  • 176 Answers
SOURCE: Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Posted on Jan 07, 2010
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
I replaced the distributor about 3 months ago. i had a tune up 2 weeks ago, and now all of a sudden my car wont start. Its not my battery and its not my starter. there was a burn mark on the positive...
check your fuses 1st, but---something made that burnt spot, is your battery too big? grounding on hood when you shut it? 2places 2 check fuses under dash @ hood.
Aug 13, 2010 | Chevrolet Camaro Cars & Trucks
Can someone explain what E74 is and ive got a few other questions
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Apr 25, 2009 | Microsoft Xbox 360 Console
Need an answer fast
wash your hand before u use your camera, the problem is from your dirty hands.
thanks
May 20, 2008 | Kodak EasyShare M853 Digital Camera
Pixels disappears form the screen
it is a rare case.you will have to replace the screen.it costs arround Rs 200/-
Jan 29, 2008 | Nokia 1110i Cellular Phone
Picture received in a small size.
try resetting the settings back to it's default or check your mms settings
Dec 29, 2007 | Sony Ericsson Z610i Cellular Phone
Ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
Aug 27, 2007 | GE 25951EE2 Phone
Uniden DCT756-3 Phone Logo
41 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
