Question about HP Officejet Pro L7680 All-In-One Printer
L7680 won't print black
Help my hp L7680 wont print black
  • HP Master
  • 419 Answers
Unfortunately it's highly likely that your black printhead is clogged due to the conditions you are using the printer in (ie: warm, dry, air-conditioned?).
I get this a lot in hot offices and school classrooms.
The only solution I've found that works long term is to use a dyebase black ink instead of the pigment ink that HP provide but this obviously means you would have to source a 3rd party ink supplier with ink of this type.
In the mean time a shorter term solution is to purchase a new black/yellow printhead and follow the process for changing the printhead for this new one.
Hope that helps.
Martin
Posted on May 19, 2009
3 Suggested Answers
TimeDefensiv
  • 746 Answers
SOURCE: HP L7680 prints red instead of black
Check your default ink setting if red is default then change it and make black ink default settings.
Thank You
Posted on Jul 28, 2009
JayBlair
  • 328 Answers
SOURCE: HP L7680 black print streeks every 5-6 lines
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
Posted on Jul 30, 2009
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP PRINTER L7680 NOT PRINTING BLACK SINCE I FITTED NEW ORIGINAL CARTRIAGE
remove the black ink , clean the contact in cartridge as well as in printer. then put back.
Sep 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Jul 30, 2009 | HP Office Equipment & Supplies
Thank You
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP L7680 has stopped printing black. The black cartridge is OK but I have replaced it with a new one to be sure. There is no error message but it just prints all other colours but not black?? HP...
Dear Its,
4 tray cartridge printer, i request you to please by orginal black cartridge ( No.18) and insert into the tray, def. it will start printing ...also if any damge from any relay or cartridge the printer wont work.
So the problem from cartridge only. pls try new.
Jun 28, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 Not printing in black!!
This is an issue of your printer settings.Uninstall the printer drivers and the software provided by Hp and reinstall it.It will do the job...
Good Luck..
Jun 23, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
336 people viewed this question
Seeker5211
Seeker5211
