Question about Clarion DC625 6-Disc CD Changer
Where is cd changer located on my pegeout 407
Pd f-407 wont pick up disc
This type of repair is tricky at best because it is a multi disc player. Some discs will jam together locking up the loading bay, also! the timing gear will go out sync, or the the plastic gears will show signs of ware causing gears to slip, the final aspect is broken worm gear and cogwheels cracked or missing a tooth. In order to repair unit must be dismantled to attempt the repair.
Apr 22, 2012 | Pioneer PD-F407 25-Disc CD Changer
How do i get my peugort 407 to reconise my cd multichanger
How do I get the Clarion CD to play on my Peugeot 206
May 21, 2011 | Clarion DC625 6-Disc CD Changer
I'm trying to locate a cd changer cartridge for my alpine cd changer in my 2000 bmw 528i.. hopefully locally
whats the model number of the alpine changer??? they usually sell for about $40-49 plus shipping. where are you located??
Mar 30, 2011 | Soundgate Abmw35v5 Alpine Cd Changer...
WE HAVE A CD PLAYER IN THE CAR ALREADY WITH A REMOVABLE FRONT BUT ONLY PLAYS ONE CD CAN WE FIT A MULTI CD CHANGER TO THE EXISTING CD PLAYER OR DO WE HAVE TO GET A COMPLETE NEW CD SET UP
several companies have multi disc CD players that are in dash..
and others have the changer in a remote location ( trunk) and are controled by the head unit..
Which model head unit do you have? It could very well fit into the later catagory and support a remote located disk changer..
Sep 29, 2010 | Car Audio & Video
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Would like to put the original CD changer/player
To put the original back in just hope the harness behind the radio wasant cut into. If its not it should just plug right in and mount back up in the stock location.
as far as the cd changer. if you would want to add one. you would need to find the changer, harness and headunit from a model with one.
May 19, 2009 | 2008 BMW 528i Sedan
2002 infiniti i35 cd 6 changer
The 6 cd changer should be located in the trunk eith on the right or left side. I hopre this helps you. Don't forget to rate my answer.
Feb 12, 2009 | 2004 Infiniti I35
2000 Lincoln Town Car Cartier CD Changer
My 2000 town car has a kenwood kcd-512c. but its only playing one track, which is what im looking for a solution to now :)
Aug 17, 2008 | Car Audio & Video
2003 Gran Cherokee CD Changer
Hi
I don't know if anyone's helped you with this yet, but to find the CD changer, open the rear door, and if you look just below the rearmost right window you'll see a hatch with a release button. Press the button, lift the lid, and there's your CD changer. Hope this is helpful. Good luck!
Aug 02, 2008 | Cherokee Jeep Grand CD Changers - 10-Disc
Connections
IDENTIFICAR CABLES DE CONEXION
Apr 23, 2008 | Alpine CHM-S620 6-Disc CD Changer
Clarion DC625 6-Disc CD Changer Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
