Question about Vivitar DVR 530 Flash Media Camcorder
How do I change the Date & Time on my GENIUS DVR-535 Vehicle Recorder
How to transfer from dvr to dvd recorder?
A DVD recorder, not connected to a computer, only can record movies.
If you have a DVD reorder connected to your PC, you need software, like NERO, to be able to write all the different codes needed to make a DVD a playable one for movie, audio or just files. (Data)
Jun 11, 2014 | Emerson EWR20V4 DVD Recorder/VCR
I have somehow changed the language into Japanese from English whilst trying to change the date. Please tell me how to change it back and also to put in the correct date.
On mine its ..
switch on .(make sure its not recording)
Record start/stop on mine is beside to on/off button
menu button twice (second menu)
on this option screen its the second option down - press record to select.
from there you can select your language.
One you've done that its the same input method for date , you just select the date and time options.
Jan 22, 2014 | HD DVR Hd Portable Dvr With 2.5 Tft Lcd...
GENIUS DVR-FHD590 UNABLE TO PLAYBACK SOME FILES
I HAVE THE SAME CAMERA AND THE SAME PROBLEM?
COULD YOU REPARE IT?
Jan 05, 2014 | Computers & Internet
Instruction manual for genius dvr-535
Http://download.geniusnet.com/manual/DVR/DVR-535/DVR-535.pdf
direct download of the manual
Dec 17, 2013 | Computers & Internet
DVR-535 Genius, I am trying to set the Time and Date. the quick quide that comes with the DVR does not mention how this is done.
first of all press menu then down button to down "date and time" then press menu go down to "date input" press rec button go down to set then press rec button use press menu button till u done time snd dste setup press menu buton to home screen check the date and time in red at botton see if correct or redo as listed here
Sep 20, 2013 | Cameras
How do i change the date to the dvr
To adjust the date and time, press the Menu button on the Remote Control, select
ADVANCED and then select DATE AND TIME
SET BY: Select MANUAL to adjust the data and time by yourself, or NETWORK to
synchronize the date and time with a time server. If you select NETWORK, then the option
of SERVER appears. Use the on-screen keypad to enter the IP address of the time server.
􀂄 DAY LIGHT SAVING: Automatically adjust the GV-Compact DVR V2 for daylight saving
time. Enter the Start and End time of daylight saving.
May 12, 2011 | Geovision GV-LX4C2V Mobile Security DVR...
L.S.My Pioneer DVR-550H does not record when programmed with the timer. After setting a timerprogram one can see the small red clock in the display but that disapears after some time and so the DVR does...
Make sure you have the right date and time set. You cannot set a timer program until you have the correct time and date set. Let me know if that helps.
Feb 20, 2011 | Pioneer DVR-550HS HDD Recorder
Vivitar DVR 530 Flash Media Camcorder Logo
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Luis Soria
Luis Soria
Level 1 Expert
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
