Question about Zanussi 24 in. DE6965 Built-in Dishwasher
What does this alarm mean?
AL7 alarm
AEG dishwasher Favorit 86450I displays error code AL7.What does it mean?
i was looking up some info about your dishwasher and this problem might be part of the control board or the pump not turning on in the dishwasher however if one is tech savy you can actually get a ardino board to run the dishwasher (seen on youtube)
Feb 23, 2017 | AEG Dishwashers
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Red alarm light is on
If the Red alarm light is on and the toner light is on means the toner need to be replaced.
If the red alarm and paper light are flashing means misfeeding or no paper, or paperjam.
Click on the link below to see what the lights all mean.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1230_all
Apr 04, 2010 | Brother HL 1230 Laser Printer
I need an instruction manual for my RCA Clock Radio Model RP3750A. Can't turn off the alarm - want radio to come on with the radio and not the alarm.
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you can have. Press Cancel and then WKx. That will turn off the alarm. If you press WKx more than once, it will cycle through small symbols on the bottom of the screen with the number x in front of them. First symbol means it will have a sound alarm for alarm x, second symbol means it will have a radio alarm and the third symbol means it will play the CD to alarm. You set the time for alarm with the slide switch at the back of the unit, selecting WK1 for alarm 1 and WK2 for alarm 2. You can have both alarms active at once, or either one singly.
Nov 15, 2009 | RCA Audio Players & Recorders
A-12 Alarm wont go away
I have an ut8k UPS I am getting an A-12 alarm. On the cover it means "tap the regulator alarm. I opened up the unit ...
May 28, 2009 | Powerware Best Power Unity/I Single-Phase...
How to activate alarm 2001 bmw 325ix doors lockand unlock with key but alarm doesn't activate, lights don't flash (new car to me) if the indicator light flashes, does it mean that you have the alarm...
The flashing light does not mean you have an alarm. They were not standard in the 3-series.
You can get one installed or if you want the dealer can program the lights to flash when locking and unlocking doors even with out alarm. This is called "acknowledgement without DWA"
May 26, 2009 | 2001 BMW 325
Connect a vga card on a used a17 mobo
Hi Rafae183, yes, you're board, Abit Al7/Al7-G supports AGP8x/4x speeds & voltage of 0.8v/1.5volts only.
Below is the Abit link for you're board. Listed on the right of the page is product Inf. & support Inf. Suggest you add this to you're favorites.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket%20478&pPRODINFO=Specifications
Suggested any one of these AGP8x speed video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
Remember to check for voltage. You're video card must run at 1.5volts only. Warranty's are important too.
Have more questions, feel free to ask.
Best of luck to you!
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | Abit A17 Guru Motherboard
Help with error code AL7
In some cases turning the machine on and off might solve the problem. Good luck !
Aug 06, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
