Question about Hotpoint Aquarius WF000 Front Load Washer
On/off switch and mini load switch flashes simultaniously
My WF540 1400 spin is three yrs old we have just got back from a 4 day break and trying to put a load on to wash but cannot. the machine will not register us pressing any buttons or programmes or even pressing the on off switch.
All it seems to want to do is run the pump to empty with water though there is no water in there. Visually it flashes the on/off switch rapidly, and the mini load flashes too but not quite so fast. I have taken a look at the printed curcuit board but there doesn't appear to be any thing carboned up or seems wrong at first glance.
Can any one help I have a feeling it could be the PCB but a lot of expence if I get it wrong.
    Problem Solver:
  • 15 Answers
Yes its the pcb cause u should not leave a washing machine on a standby mode
u should always unplug it
Posted on Jun 05, 2009
Kenmore front load washer (spprox 6 yrs old) will drain, but won't spin. Gives error F4
Hi.
No spin and F4 usually means that the problem is caused by a defective pressure switch.
The following is an extract from the washer service manual:
"F4" flashes and the cycle signal beeps when the recirculate pressure
switch is not working properly during the Catalyst, W ash or Soak cycle.
If "F4" is flashing, check the following:
- Plugged recirculate hose (black hose).
- Plugged or disconnected air tube (clear tube).
- Wires to the recirculate pressure switch disconnected or not
connected correctly.
- Failed recirculate pressure switch. Switch (black wire, tan wire)
contacts should be open with pressure applied and closed with
no pressure.
Try disconnecting power by tripping the circuit breaker or disconnecting power cord for five minutes. If that does not clear the error check the thin clear rubber hose connected to the pressure switch and extending into the tub. Try blowing into pressure hose and clean it. If that does not fix the problem replace the pressure switch.
To locate parts and diagrams, please enter the full model number, as witten in service tag, in this website.
Regards.
Ginko.
Jan 13, 2011 | Kenmore Elite 45986 Front Load Washer
My washer will not spin out, it is not flashing
intersting when mine did this it was the pump... maqy i ask how you checked your pump? and can they be cleaned i just had to replace mine and its only 2 yrs old, i dont want to have to replace every 2 yrs
Dec 30, 2009 | Frigidaire Affinity ATF7000E Front Load...
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Red icon flashing on the display screen
It's the warning to replace teh back up battery housed behind the main battery.
May 28, 2009 | Canon MV830 Mini DV Digital Camcorder
A red icon flashing on the screen.
It's the warning to replace the back up batter which is housed behind the main battery.
Kenmore top loading washing machine drains but does not spin
Sounds like the coupler broke. This connects the motor to the trans. The part is only like 25.00 and labor is about 140. When it tries to spin if the basket doesn't move at all, then this is it. If the basket is really slow or easily stopped with your hands then the clutch/trans. could be bad. More times than not, it's just the coupler. These are made to break under heavy load, so it doesn't hurt anything else. They are just rubber and plastic and sometimes break for no reason. Push the lid switch with a pen or something with the lid up and try to spin to see what happens.
Mar 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
185 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
