Question about Frigidaire Microwave Ovens
I need a wiring diagram for a fridgidaire cfmv 145 microwave
Jennair microwave jmc813odds wiring diagram
Request a wiring diagram directly from Jenn-Air.
Jun 22, 2017 | Microwave Ovens
I ran my fridgidaire microwave for 15 minutes while it was empty. Now it runs and sounds normal but will not heat food. Any suggestions?
take it in for a proper diagnosis
running a microwave empty for any period is detrimental to the magnatron and causes it to overheat and fail
a diagnosis is needed before a decision is made
Jan 22, 2017 | Microwave Ovens
Wiring diagrams for microwave model cfmv156dsb
Good Afternoon Friend, this is Z. Thank you for allowing me to assist you!
I have successfully located the Wiring Diagram of your Frigidaire microwave, CFMV156DSB. I hope this proves to be helpful to you. Should you need further assistance please feel free to reconnect.
Jul 15, 2014 | Frigidaire Microwave Ovens
Steam in between door glass on fridgidaire microwave
you must open the microwave and see if there are SOME parts burning or smell some component see the photo attached.
Oct 24, 2013 | Emerson MW8107WA Microwave Oven
Fridgidaire microwave turns on by itself
There two causes, one defective door switch, or the keypad control board is not working properly and must be replaced.
May 21, 2012 | Frigidaire Over-the-Range Microwave
I have a Fridgidaire FNV156DCC Light and timer work
check fuse inside inline with black wire and micro switches on door locks
thumbs up
Aug 17, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
My fridgidaire "FMV157GB" microwave has no power. is there a breaker?
HI, this is an unfortunate power board failuer. there has been a major burn out within the capacitor set and a diode as well. you will need to replace the power supply board in this unit asap if possible.
May 26, 2009 | Frigidaire FMV157GM Microwave Oven
Have a whirlpool MH3184XPS-3 and need a shematic wiring diagram
Found a "schematic " diagram of electrical lay out and repaired the associated problem of being mis wired.
May 01, 2009 | Whirlpool MH3184XP Microwave Oven
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
