Question about Chaintech 6VIA5T Motherboard
Seting all jumpers to motherboard chaintec 6via5t socket 379 intel
    Brigadier General:
  • 10,406 Answers
Gateway sold all the "support" for its older computers (manuals, software, hardware) to a company that went bankrupt in November 2008.
So, _no_ information about "older" Gateway computers is available online -- not even how to set jumpers.
Posted on May 18, 2009
Were can i get a manual for jumper settings
Dear,
you don't need to find out manual for jumper setting any where if you see the mother board very closely near which Jumper want to setup you can see the printed jumper setting on mother board only,
Thanks with Regad,
Ankur Goyal
Sep 10, 2015 | MSI Ms-7104 Pm8m-v Via Socket 478 Intel...
Were do the jumpers go on a optiplex 330
There is the Password jumper (PSWD), and the CMOS jumper.
The CMOS battery is also termed the RTC battery.
Real Time Clock battery.
The CMOS jumper is labeled as RTCRST.
Real Time Clock ReSeT.
Jumper pin location is confusing if you go with Dell documentation.
http://support.dell.com/support/edocs/systems/op330/en/ug/mtparts.htm#wp1607303
Dell Support documentation shows the RTCRST jumper pins near the Intel chipset, and PSWD jumper pins near the outside edge of the motherboard.
I'm also looking at the Dell Optiplex 330, Technical Guidebook, Inside the Optiplex 330,
http://www.dell.com/downloads/global/products/optix/en/optix_330_techspecs.pdf
Location of RTCRST jumper pins, is near the left corner of the Intel chipset, instead of the right as shown above, and PSWD jumper pins are in the same location.
And several views of Optiplex 330 motherboard's on Ebay,
http://www.ebay.com/itm/Dell-Optiplex-330-Motherboard-Socket-775-KP561-/140870576837?pt=Motherboards&hash=item20cc8a6ac5
(Nice to have that Zoom in feature on Ebay now)
Jumper pins close to the white SATA 2 connector, are the RTCRST jumper pins.
Jumper pins at the bottom side of the Intel chipset are the PSWD jumper pins.
Jumper cap stays on PSWD jumper pins.
No jumper cap on the RTCRST jumper pins.
http://en.community.dell.com/support-forums/desktop/f/3514/p/18683374/18806360.aspx
Regards,
joecoolvette
Oct 23, 2012 | Intel Motherboard
Downgrade intel 41 cn to support processor intel p 4 541 3.2ghz/1m/800/04a l723b 071
You need the motherboard user guide for clock settings etc but first ensure that the socket set (number and distribution of pins) on the new CPU matches that on your board. You should find a user guide on the manufacturers website, follow links for support and downloads.
Here's the page for your CPU on the intel website:-
http://ark.intel.com/products/27468/Intel-Pentium-4-Processor-541-supporting-HT-Technology-%281M-Cache-3_20-GHz-800-MHz-FSB%29
According to this, *********** board needs to have a PLGA775 CPU socket.
Assuming so, its a case of setting the clock jumpers to match the processor speed.
Feb 22, 2012 | Computers & Internet
Dear Sir/Madam, I have Intel 945 chipset gygabyte motherboard .there is no display in the monitor
- clean up memory than mount again
- check the cmos clear jumper on your mainboard
- change memory
- change transistor power ( near power socket )
Apr 27, 2010 | Intel Motherboard
HOW CLEAR INTEL D915 GAV BIOS PASSWORD
Intel mother board is very populer brand.I like it very much.If itself, It has three leg jumper near the cmos battery.1-2 short defaultor normal.2-3 short clear cmos.you like 2-3 short then fix your bios password.you must be power switch on.Un plug power cable.again jumper short 1-2 normal position. your bios clear.
Feb 08, 2010 | Intel D915GAG Socket 775 Motherboard -...
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
Turn off power and reinstall the jumper in normal mode position in intal(lga775)
if this message is appearing on your screen then the bios jumper is installed at reset position. so please install this bios jumper of your motherboard and the pin number 1-2 position of bios.
it will be allright
Apr 19, 2009 | Intel Biostar P4M800-M7A Socket LGA 775...
My Motherboard running but no beep no display of bios how can I solve the problem
refix your ram after clean it.also reset your bios setings .put your cmos cell for 15 minutes away from other bord.
also u can reset your bios setings with jumper setings.it is nearly cmos cell or corner of the motherbord put in 1-2 position then power up the cpu then refix again to its original position.
Dec 29, 2008 | Intel D946GZIS Motherboard
Computers & Internet Logo
433 people viewed this question
Top Chaintech Computers & Internet Experts
Ed Mac
WTF Chuck.....
WTF Chuck.....
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
