Question about Dryers
GE GAS DRYER MODEL # GTDP300GM1WS KEEPS SHUTTING OFF
5 Suggested Answers
  • 2318 Answers
SOURCE: ge gas dryer
Check this site for info: http://www.applianceaid.com/gas_dryer.html
Posted on Feb 21, 2008
Krazytech
  • 725 Answers
SOURCE: gas dryer heat keeps shutting
check you clame sensor
Posted on May 27, 2008
jyackle5
  • 8197 Answers
SOURCE: Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Posted on Jan 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: Roper Dryer model # RED4405Q shutting off
The motor may be getting hot due to bad rolers idler or glide. You need to take the machine apart and oil it. While you have it broken down you may want to turn the motor and see if it is stiff. The motor can be oiled but it is tricky. there are no oil ports you must make some. I use zoomspout oiler from ace hardware. Its high temp resistant formula and viscosity is perfect for dryers and HVAC needs.
75ddae3.jpgI have various essays on accessing these machines and diagnosis HERE
Posted on Mar 02, 2009
Dryer keeps shutting off
sides will feel hot
could be the timer knob or the thermostat
Sep 02, 2014 | GE Dryers
Heat keeps shutting off to my gas clothes dryer
Hi:
Most dryer have a filter to collect all partical from your clothes when you dry them. Have you clean this filter recently. If not yet Let do it.
This filter use to on the top of the dryer (next to control panel) or at the door (lower area)
Feb 26, 2011 | Kenmore 73952 Gas Dryer
Our dryer is a GE profile gas dryer. After a couple of loads drying it will stop after about 20 minutes and we will have to restart. What is the problem?
Possible that there is lint buildup on the motor and it is shutting down on overheat. Remove front of
dryer and vacuum out lint or blow it out,BUT PLEASE disconnect unit from wall outlet or trip breaker unless you want a very tight hairdo.
Feb 11, 2011 | GE Dryers
could be many reasons....if the filters are clogged or not clean the unit will overheat and shut down....check all those first before calling for a new timer/switch panel.
Jul 20, 2010 | GE DBXR463EDWW Electric Dryer
Our GE Profile dryer keeps shutting off, regardless of setting, after it has run for 4 or 5 min. Could it be overheating or maybe the vent to the outside is clogged?
it certainly sounds to me like a blocked vent issue somewhere along the line and in order to prevent a fire the safety thermostat shuts the heater off. are you saying the dryer stops altogether, not just the heat?
Oct 24, 2009 | GE Dryers
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
Fixing a gas dryer belt
That I believe is an older model GE with the idler bar instead of the short bar. I believe there is also a rear panel that you can remove to gain access to it. I dont remember for sure if it keeps tension up or down. Loop your belt around the motor pully, then find out which way it keeps tension on the belt, then loop the belt around the idler pully and release so that it keep tension on the belt itself. Let me know if you need further information.
Feb 06, 2008 | Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
