Question about Denon AVR-4308CI Receiver
No surround back channel - damage during transport
Have a Denon AVR 4308 Receiver - updated to Version 4308A. Bought the receiver three weeks ago and it has transported in a bag by plane where it has been dropped. The back panel is slightly bend where the speakers are connected. All is working except the surround channel back right. As I am living in a remote destination sending it back to the dealer or Denon is not an option. Any idea how to check what is broken and eventually how to fix it? Measured already with a voltmeter - no output at that channel. All other channels are working fine despite being pressed in around 4mm more.
  • 1 more comment
  • matthias904 May 19, 2009
    Thanks for your feedback pinout. Will try to take it apart and check the board. I have previous experience in electronics but photos of the inside would help so I know what to expect. Any idea where to find those?
    Thanks! As far as I can see the plastic strip has to be broken??? Is that a warranty seal as it is fitted without screws? Thanks so much for your valuable assistance!!!
  • 163 Answers
I think your receiver has cracked main (amplifier) board close to surround back channel terminals. Need to take apart the receiver remove the board, inspect it and resolder cracked traces. Unfortunately it is not so easy to remove that board and probably you need to bring it to a repair shop.
Posted on May 19, 2009
  • EBC ELECTRONICS May 19, 2009
    Have no picture but here is an instruction.
    Unscrew, disconnect and remove front panel.
    Remove 10 screws at binding post terminals located on back panel under plastic strip.
    Remove screws of main board and screws of heatsink. detach connectors from main board. Carefully pull main board with heatsink toward front of the unit. You will need to cut several plastic clampers keeping the wires. Good luck.
    nop, do not brake it. it has a screw on the right side end or a plastic pin, remove it.
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Were can I download a swedish manual for Denon AVR 4308
HI,
This was the closest could get on the user manual for this device.
http://www.denon.co.uk/site/popup/index.php?p=pdf&Pid=340
Thanks
proton
Aug 02, 2009 | Denon AVR-4308CI Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Denon AVR-1403 connected to DVD can hear music but no dialougue!!
Check the center channel speaker and the surround sound audio settings. If you do not have a center speaker, it needs to be set to off on the receiver.
Jan 19, 2009 | Denon AVR-1403 Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Updates
mr rusty
you might try here for more info on the demon updates there you find the req links ,
Denon 3808/4308/5308 Firmware Tracking Thread - AVS Forum
hope this some help to you.
riz.
Aug 07, 2008 | Denon AVR 3808Ci Receiver
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Denon AVR-4308CI Receiver Logo
204 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
