Question about FocalPrice UdiR / C U816 Six-Axis 2.4G Radio 6-Channels LCD Display RC Aircraft with Gyroscope
Udi u817a one of the blades stop turning - FocalPrice UdiR / C U816 Six-Axis 2.4G Radio 6-Channels LCD Display RC Aircraft with Gyroscope
Which are the best drones that will follow you?
You can get the best drones that will follow you in the Dronesglobe. Their aim is to best serve you on your drone curiosities and needs. 14 Drones That Follow You are the drones that will be best according to your need and will follow you wherever you go.
They are full with the specifications like Headless Mode, GPS, Altitude Mode, Failsafe mode and Automatic calibration.
Oct 20, 2016 | Cars & Trucks
Why did one blade stop spinning? Can I fix this? Is it now just junk?
Look for broken wires or looses connections associated with the motor that isn't running. I would also contact the manufacturer for assistance.
May 02, 2015 | UDI U817a 2 4ghz Ch 4 Axis Gyro Rc...
How do i replace blades on a u816a udi r/c
Just pull the blade you want to replace gently with your hand , you may need a protecting glove, and then push the new one in place.
Dec 26, 2014 | FocalPrice Udi U816A 2.4 GHz 4 Channel RC...
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
Instruction manual for UDI U187A says left front white blade should turn clockwise,right white blade should turn counterclockwise,left bottom should turn clockwise,right bottom should turn counter...
Out of the box my sons U817a had 2 blades rotating in the wrong direction as well. This is one example of how poor the provided directions are. First, the directions are written in Chinglish, second, they give no repair procedure for blades installed incorrectly at the factory. I'm just going to return mine. Obviously, flight was out of trim in this configuration. Hovering was all but impossible.
Feb 22, 2014 | UDI U817a 2 4ghz Ch 4 Axis Gyro Rc...
U817a loses connect to the remote control short after starting the droneflight
I would probably check to see if the crystal on the transmitter is connected properly and the wire in the reciever is clean and all the way in. Also if you're really close to a very strong power source consider moving away a bit (but your system is a 4ghz system so that shouldnt be a problem)
Dec 26, 2013 | UDI U817a 2 4ghz Ch 4 Axis Gyro Rc...
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Driver audio for iwill vx133l
you certainly do have rotton luck with this Mobo as the company no longer exists however most onboard components such as audio, vga etc are supplied by the famous IC vendors
when I have come across motherboards in the same category as the iwill, I use a nifty little tool called UDI (unknown device identifier) this has the ability to probe the ics for thier manufacturers details...... i use it to find the chip vendor then I can download and test various generic drivers for that vendor until I hit gold...so far I have had great success using this method......if you keen to try it out go ahead
you can get UDI here
http://www.zhangduo.com/udi.html
happy hunting......
Sep 24, 2010 | Iwill VX133 (MAVX133) Motherboard
FocalPrice UdiR / C U816 Six-Axis 2.4G Radio 6-Channels LCD Display RC Aircraft with Gyroscope Logo
82 people viewed this question
Top FocalPrice Televison & Video Experts
john o grady
ray gallant
Are you a FocalPrice Televison and Video Expert? Answer questions, earn points and help others
