Question about Radio Shack IndoorOutdoor Thermometer with Hygrometer
Radio shack 6300772 indoor temp not working - Radio Shack IndoorOutdoor Thermometer with Hygrometer
2 Suggested Answers
ssimons47
  • 11829 Answers
SOURCE: My Radio Shack indoor/outdoor thermometer sensor reads LL.L. Just replaced the batteries
and your point is what?
Posted on Oct 12, 2017
I have an Acurite model 00607DI and the outdoor temp, humidity, wind speed, peak and avg stopped working but pressure and indoor temp is working
That outdoor unit takes batteries and they have to be replaced. When you replace them it is a good idea to bring the unit in the house and be close to the base. They can take up to 20 minutes to start talking to each other. The pressure and indoor temp are inside the display unit. Make sure that there are no other strong radio signals in the house that can interfere with reception.
Apr 16, 2018 | Measuring Tools & Sensors
Antena for bose radio?
The Bose uses its power cord as an FM antenna. Make sure it's reasonably stretched out (not coiled), and is not in surroundings that shield it from the outside (a steel frame building, though even here putting it close to a window can give you reception). If this isn't enough to get stations clearly, there is a jack on the back of the radio where you can plug in a dipole (piece of wire) antenna available from Bose -- not cheap for what it is -- an indoor antenna from Radio Shack or a similar store, or even a roof-mounted unit. If you don't buy from Bose, you'll need an adapter to convert from the standard plug everyone else uses to the phone jack Bose has decided to use instead. Radio Shack sells one: catalog 278-257.
Jul 13, 2014 | Bose Wave Radio
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Cobra 19dx iv when i key up it swings all the way to a 9 is there any way to set swr,s without a meter
Just buy a factory built antenna/(it should be close) Buy you a magnet mount RADIO SHACK job(works). If your indoors buy ANTRON A99(set at 1.3 SWR factory). If it keys 9 db then that equals 4 watts output thats OK.
Apr 02, 2011 | Cobra 19 DX IV CB Radio
How long does the battery on the mosquito last? It's not holding a charge stong enough to stay in the air. I'm using radio shack batteries, will energizers give me a stronger charge?
I am not endorsing one brand over another, but I have had better luck with the main brand name alkaline batteries. Just for fun, compare the weight of the Energizers to the R.S., you might be surprised.
Oct 04, 2010 | Radio Shack Indoor Micro Mosquito Rc...
My 320 is powered up and running but is not collecting any moisture
low outside temp means low indoor humidity
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 22, 2009 | Amcor MD250 Dehumidifier
Need to connect an indoor FM antenna to the receiver the 75 ohm connection is only bare wire
the indoor antenna you have must have a screw on connector and the receiver has a smooth connector or you would already have it hooked up. Go to Radio Shack and buy a connector that turns the coax into a slip on style.
Aug 14, 2009 | Pioneer VSX-453 Receiver
No TV Reception
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
Jan 16, 2009 | Sony KP-53V75 53" Rear Projection...
Radio Shack IndoorOutdoor Thermometer with Hygrometer Logo
85 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
 steve
steve
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
