Dryer won't run fault code EoP cissell dryer - Washing Machines
2 Suggested Answers
SOURCE: Cissell Dryer Model HD30ST gives
I had the same problem with our Cissell L125URDG with the error code P-F. Found out it means Plug #4 on our wiring shematic. On this plug there are several sensors connected to this plug: highlimit switch, air switch, thermistor, door switch, and a bonnet thermostat. So, it is probably one these switches that is given this error code P-F.
Posted on Nov 09, 2008
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
2003 4500. Why have gauges stopped working?
You could have anyone of a number of different problems . I know your year vehicle falls in the range of GM instrument culster problems . There are little stepper motors ( electric motors ) that make the gauges move . There could be DTC'S - diagnostic trouble codes stored in the instrument cluster . An you have to know how the instrument cluster knows how much to move the needles on the gauges . All the input sensors to the PCM/ECM - engine computer vehicle speed sensor , fuel pressure , oil pressure , etc... All the modules on the truck are hooked together on a serial data communication network .The PCM/ECM sends this information out on the data bus for the other moduels that need the info .
Engine Oil Pressure (EOP) Gage
The IPC displays the engine oil pressure on the analog EOP gage as determined by the PCM. The PCM monitors the signal circuit of the EOP sensor. When the EOP sensor resistance is high, the engine oil pressure is high. When the EOP sensor resistance is low, the engine oil pressure is low. The IPC receives a class 2 message from the PCM indicating the engine oil pressure. The EOP gage defaults to 0 kPa (0 psi) when the following conditions occur:
• The PCM detects a malfunction in the engine oil pressure sensor signal circuit. Refer to Diagnostic System Check - Instrument Cluster .
• The IPC detects a loss of class 2 communication with the PCM.
Speedometer
The IPC displays the vehicle speed on the analog speedometer based on the vehicle speed signal from the PCM. The PCM converts the data from the vehicle speed sensor to a 4000 pulses/mile signal. The IPC uses the vehicle speed signal circuit from the PCM in order to calculate the vehicle speed.
The powertrain control module (PCM) creates the vehicle speed signal by pulsing the signal circuit to ground at a rate of 4K PPM. The instrument panel cluster (IPC) converts the 4K PPM signal to a speedometer position. The IPC also receives a class 2 message from the PCM indicating the vehicle speed. The IPC uses this class 2 message for diagnostic purposes.
There could be up to twenty different DTC'S stored ,here is an a for instance
DTC B1365
The instrument panel cluster (IPC) uses the ignition 0 voltage circuit in order to supply voltage to various indicators and gages. The IPC also receives a class 2 message from the serial data gateway module (SDGM) indicating the current power mode. Your best bet would be to take your vehicle to the Dealer or an ASE certified independant repair shop .
Dec 21, 2015 | 2003 Chevrolet Express
Have a cissell 170lb dryer it will ignite than flame will go out
Most likely problem with ignitor. You can try cleaning the ignitor. One reason I can think of is that the feedback from the ignitor circuit is not working. What usually happen is that when the flame have started. The ignitor will generate a small current to tell the ignitor control board that there is a presence of flame. If the small current feedback is not detected. the system will automatically shut off the gas for safety reason. You probably tried stopping and restarting and the same condition will occur.
Jan 28, 2013 | Cissell Parts Cissell H87533014 Dryer...
What does the fault code 35 mean on a freightliner truck
Flash Code 35 indicates that the engine Oil Pressure Sensor/Engine Oil Pressure Sensor (OPS/EOP Sensor),input to the ECM/ECU has exceeded 95% (normally > 4.75 volts) of the sensor supply voltage.? This is more then likely a faulty oil pressure sensor or wiring to sensor issue
Nov 02, 2012 | Cars & Trucks
I need a service manual for a Cissell Comercial Dryer model HD50G1
hi .my hd50g1 wont light up . we had a problem with the motor and had that rewound, now it wont ignite....it starts spinning and everything except no gas flow or ignition.
Oct 21, 2010 | Dryers
Cissell Dryer Model HD30ST gives an error code P-F. I would like to know what this means.
Aug 30, 2008 | Dryers
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
