Question about Sony CDX-GT500 CD Player
Replaced rear factory speakers now have low volume
Sony cdx gt 500, rear factory speakers quit worgking. replaced with alpine, now rear speakers work but low volume compared to the front factory speakers.
    President:
  • 676 Answers
Factory speakers usually have low resistance ( 2 ohm) When replacing speakers with aftermarket, most aftermarket speakers will be 4 ohm. If you want the same sound you may have to buy some resistors to put on the speakers (across the + and -). By putting a 4 ohm resistor across the connectors will now make the speaker 2 ohms which in effect will raise the volume. Depending in what vehicle you replaced the speakers the resistance will vary.
Posted on May 18, 2009
  • 3 Answers
You may want to check your rear speaker wires are any of the : + and - crossed. This could cause the same result.
Posted on Nov 12, 2011
Sony CDX-5005 factory installed in a Bryant boat... no out put in any mode to speakers. What replacement unit will fit and hook up to existing harness?
Any DIN style radio will fit onto the existing cut out.
Stay with Sony CDX family. The connect and color code will be the same.
Do you still has the remote control for this Sony CDX-C5005?
This remote has an "ATT" (almost like mute) //// lower left hand button.
Aim the remote to the radio and press the ATT button and see is the volume restore to normal.
Click HERE (skip to page 6) for a sample picture of the remote.
Jul 28, 2011 | Sony CDX-C5005 CD Player
Need wiring diagram for soy cdx-gt150
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
May 03, 2011 | Car Audio & Video
Str-de545 sony not putting out sound to rear speakers
From page 46 (Troubleshooting)-
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
Jan 11, 2011 | Sony STR-DE545 Receiver
Rear speakers L and R not working and MD in and out not working on my Sony STR-DB940
I'm guessing these are separate issues.
Has either one ever worked and stopped suddenly?
From the manual:
"No sound or only a very low level sound is heard from the rear speakers.
>>> Select a sound field containing the word "cinema" or "virtual" (see page 33-35).
>>> Adjust the speaker volume (see page 72).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 20)."
Be advised that using any Tape Monitor loop (that's what the MD/DAT is) disables any digital sources. Not that that would explain the rear speaker failure. Analog sources can still be processed into various surround modes.
Any Tape Monitor use requires at least a live INPUT to hear anything.
May 29, 2010 | Sony STR-DB940 Receiver
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
I own a Sony-Ericsson P1i. Its sound volume is very low and though I have kept it on the maximum, I can barely hear the opposite person talking to me. But the music volume is okay, and so is the headphone...
I had this problem too but i found this on the web so i'm gonna copy paste . Good luck!
"The low volume in the in calls in SE P1 / P1i can be easily solved in this way/hack:
(Thanks to montsma, the Junior Member AT noeman.org)
Speaker volume in P1i Service Menu
Go to the Main Menu > Phone > Phone to open the virtual numeric keyboard.
Do the following;
- 1 click up on jog dial and press (*)
- 2 clicks down on jog dial and press (*)
- 1 click down on jog dial and press (*)
to open the hidden Service Menus part of the phone.
Then go to the Service Tests > Speakers.
There are two selections, rear and front, and the "front" adjusts the volume of the ear speaker, which is used during the calls. Increase the volume to %100. Quit the Service Menus and make your call. I made one try and it was cool!"
Apr 03, 2009 | Sony Ericsson P1i
Speaker Pop when i turn on or change tune on radio
the speaker is probably worn is it factory is the speaker wires crossed need more detail
Mar 09, 2008 | Sony CDX-GT710 CD Player
Rear speakers
If have a VOM check for voltage at the amp. If not, a cheap trouble light (often in cheap tool bin) will tell if have voltage. this will tell if the problem is the head unit or the amp or wiring.
Occasionally the remote wire will have a fuse in line.
Jan 05, 2008 | Sony CDX-GT710 CD Player
Sony CDX-GT500 CD Player Logo
209 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
