Question about Camping, Backpacking & Hiking
Remove headlight assembly - Camping, Backpacking & Hiking
Headlight bulb replacement. Does headlight need to be removed?
If there is enough of room, you do not need to remove headlight assembly. If not remove whole assembly to make it easier to get to. For headlight assembly remove the 2-10mm bolts on top of assembly, there is a 10mm bolt on inside bottom that has to come out. Unplug the wires to assembly. When removing assembly, pull from grill side and wiggle it out. God-Bless! Remove the 3 10mm bolts from assembly.
Mar 14, 2015 | 2004 Hyundai Sonata GLS
REPLACE HEADLIGHT 2008 SPRINTER
On some cases there are few hidden clips holding the assembly from under hood,that has to be released to remove headlight .
There are few troubleshooting help links showing how to replace car headlights,i suggest you to refer the links to solve these issue.
Click the link below:------
How to Replace a Headlight http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
How to Replace a Headlight Switch http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Low beam headlights Modification? http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html --------------- Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a Headlight Door http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
These will help.
Thanks.
Nov 23, 2012 | 2010 Mercedes-Benz Sprinter
Replace headlight bulb
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
  26. STEP:
  27. PLS VOTE ME
BMW e46 HID Headlight Replace
Nov 23, 2012 | 2000 GMC Denali
How do i change my headlight assembly on a 2001 honda accord
HEADLIGHT REPLACEMENT
1. Remove the front bumper
2. Disconnect the connectors (A).
3. Remove the 5 mounting bolts (B), then remove the headlight assembly (C).
Fig. 21: Removing Mounting Bolts & Headlight Assembly
Jun 24, 2012 | 2001 Honda Accord
HOW DO YOU REMOVE THE ASSEMBLY ON THE OLDS 95 SO I CAN CHAGNE THE LIGHTS.. I REMOVED TWO SCRES IN THE FRONT BU IT DOES NOT HELP TO REMOVE THE ASSEMBLY
Step 1:
Be sure the ignition key is not in the ignition, and the headlight switch is in the "Off" position.
Step 2:
Locate and remove the two headlight assembly screws on the top rail of the headlight assembly. Use the nut driver to remove them.
Step 3:
Place a rag between the headlight assembly and the bumper to protect the paint.
Step 4:
Wrangle the assembly outward. There is a guide pin behind the assembly on the fender side that holds it in place. This needs to be popped out of its socket in order to remove the headlight assembly. Pull slightly outward from the side, then forward and away from the car.
Step 5:
Locate the correct bulb socket (high-beam/low-beam). Disconnect the wire connector using the flathead screwdriver.
Step 6:
Turn the socket 1/4-turn counterclockwise to remove the socket from the headlight assembly. Remove the old bulb.
Step 7:
Insert the new bulb into the headlight assembly, and turn clockwise to lock into place. Be careful not to touch the glass bulb of the new socket. This could degrade headlight performance.
Step 8:
Reconnect the wire connector to the bulb. Test the light before replacing the headlight assembly, then turn off the lights again.
Step 9:
Reinsert the headlight assembly, making sure to align the guide pin into the socket. Replace the screws and tighten.
Feb 12, 2011 | 1995 Oldsmobile Aurora
How do you remove the headlights off a Pontiac grand am 2004
Lighting Headlight, Side Marker, Park & Turn Signal Assembly Removal & Installation To Remove:
  1. Open the hood.
  2. Remove the front air deflector.
  3. Apply light pressure to the headlight lens to hold the headlight in place while disconnecting the retainers.
  4. Lift up the headlight retainers to release the housing.
  5. Remove the headlight assembly, pulling straight forward from the headlight mounting panel. NOTE: Note the location and position of the adjuster retainers and locator tab.
  6. Disconnect the wiring harness from the headlight assembly.
  7. Rotate the bulb(s)/socket(s) as needed counterclockwise to release.
  8. Remove the bulb(s)/socket(s) from the headlight assembly.
To Install:
  1. Install the replacement bulb(s)/socket(s) to the headlight assembly rotating clockwise until fully seated.
  2. Connect the wiring harness to the headlight assembly.
  3. Position the headlight assembly to the mounting panel.
  4. Apply light pressure to the headlight assembly lens to hold the assembly in place while installing the retainers.
  5. Align the headlight assembly retainers and slide them over the assembly mounting tabs
  6. Install the front air deflector.
  7. Close the hood.
Feb 02, 2011 | 2004 Pontiac Grand Am
Once I remove the nuts and bolts, I can't get the headlight to move
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative (-) battery terminal.
  3. Loosen the mounting bolts and nut of headlight assembly (A).
    Loosen the mounting bolts and nut of headlight assembly (A)-Santa Fe
    Loosen the mounting bolts and nut of headlight assembly-Veracruz
    Click to Enlarge
  4. Take care that retaining clip (A) is not to be damaged-Santa Fe.
  5. Disconnect the headlight electrical connectors.
  6. Remove the headlight assembly.
  7. Remove the headlight bulb:
    • Remove the headlight bulb(s) with a counterclockwise turn-Santa Fe.
    • Remove the headlight bulb after removing the bulb caps (A)-Veracruz.
      Remove the head lamp bulb(s) with a counterclockwise turn-Santa Fe
To install:
  1. Install the headlight bulbs.
  2. Install the headlight bulb caps-Veracruz.
  3. Connect the headlight electrical connector.
  4. Install the headlight assembly.
once bolts out lift up on the headlight unit hope this helps plz vote comment reply if you need more help
Jan 17, 2011 | 2007 Hyundai Santa Fe Limited
How do I remove halogen low beam head light to replace it?
WARNING
The halogen fog light bulb contains gas under pressure. The bulb may shatter if the glass envelope is scratched or if the bulb is dropped. Handle the bulb only by its base. Avoid touching the glass envelope.
NOTE: The headlight bulb should not be removed from the headlight assembly until just before a replacement bulb is installed. Removing the bulb for an extended period of time may affect headlight bulb performance. Contaminants may enter the headlight assembly where they can settle on the lens and reflector. Never turn on the headlights with the bulb removed.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. NOTE: Make sure that the headlight switch and the ignition switch are in the OFF position.
  2. Remove the pin-type retainers, screws and the air deflector from the radiator.
  3. Remove the three bolts and the headlight assembly.
  4. Disconnect the electrical connector.
  5. Remove the cover from the rear of the headlight assembly.
  6. If equipped with HID, release the spring tabs to remove the low beam bulb, otherwise disconnect the electrical connector and remove the bulb.
  7. Disconnect the electrical connector and remove the high beam bulb.
To Install:
  1. Place the headlight assembly in the proper position.
  2. Install the cover from the rear of the headlight assembly.
  3. Connect the electrical connector.
  4. Install the three bolts and the headlight assembly.
  5. Install the radiator air deflector.
Dec 18, 2010 | 2003 Lincoln Town Car
Removing and reinstalling a new headlight assembly in a 95 jeep grand cheerokee
LIGHTING Headlights REMOVAL & INSTALLATION Cherokee, Wagoneer and Comanche Models Fig. 1: Remove the top corner headlight bezel mounting screw 91076p12.jpg
Fig. 2: To access the turn signal bulb or headlight bezel mounting screws, remove the 2 turn signal housing retaining screws 91076p13.jpg
Fig. 3: After removing the turn signal housing from the headlight bezel, remove the 2 bezel mounting screws . . . 91076p27.jpg
Fig. 4: . . . then carefully pull the headlight bezel away from the headlight assembly 91076p11.jpg
Fig. 5: Remove the 4 headlight assembly retaining ring screws . . . 91076p07.jpg
Fig. 6: . . . then pull the retaining ring off of the headlight assembly 91076p06.jpg
Fig. 7: Pull the headlight assembly away from the vehicle just far enough to disengage the electrical connector from behind the headlight 91076p28.jpg
  1. Remove the headlamp bezel and retaining ring attaching screws. Remove the bezel and retaining ring.
  2. Pull the headlight out, disconnect the wire harness and remove the headlight from the vehicle.
  3. Install the headlight in the reverse order of removal.
Grand Cherokee and Grand Wagoneer Models
  1. Open the hood, reach into the engine compartment and locate the lock ring supporting the bulb assembly.
  2. Rotate the lock ring 1?8 turn counterclockwise and pull the bulb straight out from the housing. To install:
  3. Install a new bulb and position the bulb assembly in the lamp housing.
  4. Rotate the lock ring 1?8 turn clockwise to secure.
The Grand Cherokee will have an assembly that is fastened with bolts and screws to the body.
Get the new assembly and compare to the old one to see where to unfasten the bolts and other fasteners to aid in removing quickly.
Oct 08, 2010 | 1995 Jeep Grand Cherokee
Headlight removal
1) Lift up on the headlight retainer to release the headlight assembly. 2) Release the headlight ball studs from the grommets by pulling the headlight assembly from the lower center corner. 3)Remove the headlight assembly from the upper fascia support. 4) Disconnect the harness connector from the headlight assembly. 5) Remove the headlight assembly from the vehicle. 6) Remove the access cover from the rear of the headlight assembly. 7) Remove the headlight bulb socket from the headlight assembly by rotating counterclockwise . 8) Remove the headlight bulb from the socket. Reverse these steps to install and make sure when your done to adjust the headlight.
Jun 17, 2009 | 2005 Pontiac Aztek
Camping, Backpacking & Hiking Logo
512 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
