Question about NetGear WGR614 Wireless Router
Router wont turn on when i plug it into the wall.
I plug in my router to the wall. and it wont turn on. no lights come on. is this fixable? if yes how can i fix it?
  • boodhram_10 May 18, 2009
    i had tested the power supply with my volt meter and that works fine. i dont where to check for power on the router.. so the problem is with the router im guessing.
    any other suggestions i can try?
    President:
  • 623 Answers
That sounds like your power adapter is not working properly.
You can either
  1. replace it if you have one lying around with the same specifications (make sure the small plug fits in the router!)
  2. using a voltmeter to test if there is any power at the output
  3. take your router to an electronic store and let them test the power supply or the router.
The specs for your adapter are:
Input: 110V / 60Hz
Output: 12V / 1Amp
That means:
The voltage should be within +/- 10% of 12V. More is not ok.
Any other adapter has to be able to deliver at least 1 Amp. More is ok.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 18, 2009
  •  C. Dante
    C. Dante May 19, 2009
    Darn!
    That of course would have been easy!
    Sorry, but I never took this router apart. You can always open the housing and have a look around to wee if there is any fuse or other obvious damage, but I'm not good enough with electronics to give you a better advice.
    Maybe someone else around here?
    Come on all you modders and hackers - help him/her out!
Nook hd wont turn on
Does this have anything to do with "Problem with Routers"?
Nov 13, 2013 | Computers & Internet
Panasonic Viera plasma suddenly shut off and wont turn back on and when off it has a dark line on screen
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
Nov 13, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
There is no power. it wont turn on.
Hey brother. Try these few steps i am sure these you can diagnose what causing this problem:-
1.As you said the power light does not turn on in router then I may be a possibility that power adapter which connected from router to Wall socket may be loose or wall socket may by have some issue So try to connect your Router with different wall socket and check have got the power light. Now check your router power light. If it is off then try step 2.
2.Try to reset your router which you can do by inserting a paper click in the back of the Router. In the back of the router you will have a small black whole where you can try to insert this paper click for 30 seconds and see if you have got the power light.
3.If still you don't have the power light that means most probably your router is faulty now. If it under 1 year or under warranty you can replace it free of cost.
Mar 06, 2011 | Dynex DXWEGRTR Router
My wall-plug says it can't get in ip adress. It also says that it can't even connect to the network. Is this fixable? If yes, how? (P.S. This isused for my xbox by me, if that helps anything.)
The device is for "bridge the networks" each other PC,Laptop,etc...,is not a router.The device communicates with the router so you can have better "signal" between any device that want access to your network.
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back! Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
Dec 08, 2010 | NetGear Powerline XE102 Ethernet Bridge...
Was playing and someone came in and turned off the lights in the room, the power supply was hooked up to that switch and shut everything down. i tried to turn it back on and didnt work. tried changing the...
if you were either downloading a update or a game update or playing a game while it was loading you have a bricked wii
fixable but req some stuff
some way req hardware and software
others are only software
Oct 18, 2009 | Nintendo Wii Console
Are the lights on my wireless router supposed to be blinking?
yes it is fixable but try 1st to reset the original the settings of your modem if you have then reboot the PC.thanks and good luck have a nice day
Sep 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
I cant get it to turn on
Hi TweyTwey,
Is this a new router? Are you sure that you are using the correct power adapter, if you are then the adapter might be faulty! Try another adapter. Also, be sure that the wall socket you are plugged into is functioning...test it with a light. There is one other thing you might try. If you look on the back of the router, you will see a reset slot. You can use a pen and push and hold the reset for a moment to cause it to recycle. If none of these things solve the issue then I would suspect that the router is defective.
--RoadHawk
Nov 25, 2007 | Linksys Wireless-G Broadband Router
Belkin wireless g router wont turn on
check weather the power adpter making issues>and check with surge and power stripe and try connecting directly to the wall scores still if its not on replace teh power adapter or replace the device i think u have warreny so u will not get charged>rate me solved if its helps thx
Nov 07, 2007 | Belkin (F5D72304F5D7000) Router
NetGear WGR614 Wireless Router Logo
290 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
