Question about Toshiba TEC B-SX4 Thermal Label Printer
Pb error sx4
Pb paper sx4
2 Suggested Answers
  • 19 Answers
SOURCE: paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Posted on Jan 25, 2010
Toshiba TEC B-SX4 paper jam
Size problem or type of material problem or recalibrate the sensors.
All in the owner's manaul
Mar 05, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a brand new SX4 with a rotary cutter. I am printing 2 types of tickets, one with a black mark and one with a notch cut out of the side (gap). The problem I am having is that when printing the...
Your problem is related to the size of your Tags.
When the label is fed to be cut, the notch is placed on the sensor. Since there is no paper the value recorded says no paper. Try to recalibrate the sensors or stick a piece of liner on the sensor.
Feb 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Feb 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
ERROR READS OUT OF PAPER,BUT IT IS NOT!
you have to callibrate the sensors
(5) sensor adj. in the menu
Feb 08, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
C 0204
C0204 is an error to tell u that behind the tray 2, you'll have a paper that satyed after a jam. remove the paper, and push the interrupter ON/OFF. it will solve the pb.
Jan 17, 2011 | Konica Minolta bizhub C250 All-In-One...
Ts an sx4t version 5.1 and it comes up with a error message - d042010000390.
this is a syntax error
Normally you should send
{D0420,1000,0390'} for paper size
Aug 25, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
System error showing on my toshiba tech sx4
Hi Thanks for your question.
First thing you should try is unplugging your printer from mains and plugging back again after 30 sec or so. Good Luck
May 10, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Download a new firmware.
- check that the antiparasite cores are mounted on the ribbon motor cables
Mar 16, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
PAPER JAM
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 05, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Paper jam error message
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
47 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
