Question about Sony Playstation 3 (PS3) Console
Cannot output 1080p with a full hd 1080p hdtv
I definitley do have a FULL HD 1080p lcd tv and i bought a highly expensive hdmi cable and it is only outputting 1080i , please help someone
  • Devon Patrick Adkins May 19, 2009
    na did'nt work the tv tried to pick up 1080p and stays blank.automatically it just brings you back to automatic or custom settings
  • Devon Patrick Adkins May 20, 2009
    dude lol, good one but obviousily i know that, maybe i'm not asking the question correctly, MY TV AND PS3 ARE ON and i can get a maximum output of 1080i but my dear freinds my hdtv supports 1080p even mp ps3 tries to output 1080p but my screen goes blank for 2 seconds then displays snowy white then goes balnk again then when it re - appears it shows the automatic and custom settings page. Hope this helps.
    Sniper:
  • 64 Answers
In the settings menu, go to video settings. You can have the PS3 search for "optimal settings" This will tackle both video & audio.
On a side note, you didn't need to spend all that money a HDMI cable. ( I'll bet it's a 'Monster' cable, right? ) The $16 Phillips at walmart is just as good. Unless your doing "broadcast quality digital" work, the expensive cables are overkill. Sorry, bro.
Posted on May 19, 2009
You have a degree in computers & you don't know that both your tv & ps3 have to be on & running before you plug in any hdmi? lol. Hope you didn't over pay for the degree like you did for the cord
Posted on May 20, 2009
My VIZIO 1080P cannot connect thru HDMI cable To My Laptop
Just use the VGA/PC input instead. It requires an rs232 cable. It's HD and will automatically adjust the proper settings for the display.
Jun 08, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
276 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
