Question about Medion M3 Composer 5200 PC Desktop
Fan runs all the time. I've cleaned the insides and put on some additional silcone grease between microprocessor and heat sink, but still runs. It seems to me that when I first used the computer, the fan run occasionally.
  • Anonymous Feb 18, 2008
    My fan on the hard drive runs all the time. It is so loud it wakes us up at night on the second floor. It is maddening when you are sitting just a foot away! This cannot be normal.
Its not normal
Posted on Mar 11, 2008
  • 4,889 Answers
Thats not a problem...Your fans(3 of em')need to be running to kepp your CPU cool...Dont worry..its normal
Posted on Oct 18, 2007
Dell inspiron 2020 all in one fan problems
I have found that if the room temperature near the computer is too high creates a problem. If the processor is being used at a high rate that will influence the temp sensors and cause the fan to run at the "speed" you hear. (It is on all the time, just different speeds). Other heat producers may not have clean fans or fins, for example display adaptor or power supply. or but unlikely, the
cpu fan interface is not well seated or no heat transfer grease. You didn't change the processor did you?
Apr 05, 2015 | Dell Inspiron One 2020 Desktop Intel Core...
Why does my fan on my Gateway ZX4931 always run loud?
does it has variable speed feature?, clean the heat dissipator, is clogged with lint and hairs! and always runs @ full speed, also if you're already there, might as well reapply thermal grease to the thermal dissipator.
ALSO, because you will have the fan dismounted, is so cheap you can put a NEW QUALITY fan (or fan dissipator combo) sometimes bearings gets loose and the axle wobbles (because of costs all OEM fans runs on cheap bushings) new aftermarket PRO-fans runs on ball bearings.
did you checked if a loose wire is not touching the fan blades?
Aug 06, 2014 | Gateway Computers & Internet
I accidentally spilled nail polish remover on my macbook. it works fine now but i've noticed the fan runs more frequently now. is this normal?
it's possible you got some inside your mac. When it heats up, can you smell the remover? It might be that it dried inside and is being reheated every time you use the mac.
Jun 03, 2012 | Apple MacBook Mac Notebook
My HP Pavilion dv6 WW146AV runs hot!
In order to address this the unit must be taken apart, remove fan and clean with compressed air, next remove the heat sink, four spring loaded screws turn one "small amount" go diaganal do the same and the next two until removed from the processor ic, blow out any dirt, next remove old silicon grease with rubbing alcohol, apply fresh thermal grease to the ic and heat sink "small amount" and assemble.This will solve most issues.
Mar 05, 2012 | HEWLETT-PACKARD Computers & Internet
A85S107 Toshiba Laptop: Laptop will run for approx 6 min and gets hot and shuts off. Cooling fan clear and runs properly. Tried cooling pad to no avail.
If you are sure that it's not the fan in question then you'll need to check the heat sink could be too much or too little thermal compound
Sep 05, 2011 | Toshiba Satellite A85-S107 Notebook
When i have it plugged in it will turn on and work for 5 minutes or so and then it will turn off and same thing with when it's unplugged. what the problem?
It sounds like your CPU is overheating. You've not mentioned whether a laptop or desktop PC.
Desktop - disconnect everything, take it outside if not raining and clean out all the dust and rubbish you can, I ( VERY CAREFULLY) use a dry paint brush. Pay particular attention to the CPU fan and heat dispersal block. More or less in the middle of the mother board, try and clean out the metal vanes. Also clean around the PSU fan assembly. Check all cables are good and home. Re-assemble and try again.
If it keeps on, its probably best to talk to someone who knows a bit more, or, as above, remove the CPU fan assembly and heat dispersal plate, clean CPU but leave it in the mother board, also clean the heat dispersal plate, (The goo is heat dispersal grease to ensure good contact between CPU and plate) Replace the grease and re-assemble.
A tip is to connect the power supply just before putting the case cover back on, powering up and checking that the CPU fan is working OK.
You can get loads of tips and videos from You tube.
If a laptop, the clear out the dust in the vents on the side and underneath, if that doesn't work, it means dismantling your laptop to clean it out. Your still trying to achieve what I've described above.
Sep 03, 2011 | Computers & Internet
My GM5472 (AMD Chip) has been running very hot over the past few weeks - over 100 degrees C! I've cleaned the fans out and now have a fan leaning against the box, which keeps the temp down. Question is -...
-try adding additional fan in the casing -in adding fan make sure that you have a blower fan and a exhaust fan where in air can get in and out inside the case.
-add thermal paste/grease between the processor and the heat sink. it is often used to aid the processor's thermal or heat transfer via heat sink. -you can also add blower fan in the chipset of the motherboard -you can also add heatspreader in the memory. -check the power supply if you are getting enough power -having too much power may result in over heating and may damage the devices -having less power may result slow system and bad performance.
Apr 27, 2011 | Gateway GM5472 PC Desktop
Thinkpad 2373: boot and freeze problems.
If you are having trouble with your fan running it is possible that the notebook is over heating.
Think about when it ran good and when it did not. Was the fan running and/or was it cooler at that time. Also if you are in a place where it is cool outside you might take the system outside in the cool to see if this makes a difference.
If is does work more when it is colder then most likely the fan is not cooling the system properly.
Let me know if you have any more problems or questions
Jan 18, 2010 | IBM ThinkPad T40 2373 Notebook
Compaq presario 6000 turns on but won't boot up.
Even though you said no pins were bent, my guess is that one of the pins either bent or broke off completely.
I am assuming that since you were inside cleaning, the computer is out of warranty.
Try examining the CPU (thingy under the fan) for any bent pins or broken pins. The alignment back into the mother board is crucial. Usually there is one corner with no pin or the corner is squared off to indicate the positioning of the chip in the pin holes.
Reseat the CPU and make sure it goes all the way down flush to the motherboard.
Usually there is a lever beside the CPU that you can lift that makes it easy to install or remove the CPU. It is called a Zero Insertion Force (ZIF) lever.
Personally, I'd recommend a professional or very knowledgeable and experienced friend help you reseat the CPU. Otherwise, you will need to replace it and they are not cheap.
However, if the CPU is damaged beyond repair, you might find a good USED one online at a decent price.
Dec 28, 2008 | Compaq Presario 5000 PC Desktop
Medion M3 Composer 5200 PC Desktop Logo
383 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
