Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Trying 2 open all ports - Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
    Brigadier General:
  • 10,406 Answers
Don't try! The whole point of "security" is to _ONLY_ open those ports that your system needs.
If you really think that you must do it, read about the 'DMZ' ("De- Militarized Zone") feature of your router.
Posted on May 18, 2009
Port fording code for digital samsung tv
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Mar 25, 2010 | NetGear DG834G Router
Cant connect to xbox live..have plugged ethnernet cable into xbox console and eircom wireless system..get message cant download tyhe update test your settings,,can you advise me?
try opening yur NAT setting , ring xbox customer support and ask them 4 the UDP ports that u need , then go 2 your pc and go in2 NTWORK CONECTIONS, in there u need 2 right click on your eircom internet and go 2 the bottom were it says propertys, click on it , this should bring up a box of propertys u want 2 go 2 were it says advanced and click on it , then go 2 add port and put them in 1 after another there should be 3 ports u need , this will give u a open NAT , and downloading the update should work. MAKE SURE U REBOOT YUR PC AFTER PUTTING IN THE NEW PORTS.
Jan 11, 2010 | Microsoft Xbox Console
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
At the front of computer, the 2 usb are not working
Hello
If you have recently formatted or opened your case, this might just be a case of some wires not pluged in correctly, or chipset drivers not installed. Try installing chipset drivers again, if that does not work open your case and trace the wires back from the front panel and plug them out and back in again. Really hope this can help you.Please rate this.
Best regards
Sep 26, 2009 | Acer Aspire L100 PC Desktop
Need to open port on a netgear
A. Determining the IP Address and MAC Address of a Computer (street fighter1v):
1. Please open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
Feb 01, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Netgear dgn 2000 port trigering
Port Forwarding A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Opening Pre-Defined Ports for Internet Services: 1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu. 2. Please select the service type Port Forwarding. The router pre-defined services are listed there. 3. From the Service Name pull down list, select the service that needs to be hosted. 4. Enter the IP address of the computer in the Server IP Address box. 5. Click the Add or Apply button. 6. Repeat all steps to open more ports. Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below: D. Opening Ports for Games, Applications or Custom Ports: 1. Click on Add Custom Service button. 2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box. 3. If the application uses only a single port; type in the same port number in the Ending Port box. 4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box. 5. Type the IP address of the computer in the Server IP Address box. Click Apply button. 6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation. 7. Repeat all steps to add more ports for more services. E. To Edit or Delete a Service Entry: 1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page. 2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
NAT
A. Determining the IP Address and MAC Address of a Computer/Game Console (PS3, XBOX, Wii, etc...):
NOTE: Port numbers can be provided by Tech support of each Console game Manufacturer..You can call them first...
Jun 19, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Change NAT to open
The ports should be opened only in the router not in the x.box, go to a working pc..
To allow traffic from the internet to enter your local network, you will need to open up ports or the router will block the request.
Because our routers use NAT (Network Address Translation), you can only open a specific port or ports to one computer at a time. For example: If you have 2 web servers on your network, you cannot open port 80 to both computers. You will need to configure 1 of the web servers to use port 81. Now you can open port 80 to the first computer and then open port 81 to the other computer.
  • Step 1 Open your web browser and enter the IP address of your D-Link router (192.168.0.1). Enter username (admin) and your password (blank by default).
    Step 2 Click on the Advanced tab at the top and then click Virtual Server on the left side.
    Step 3 Check Enabled to activate entry.
    Step 4 Enter a name for your virtual server entry.
    Step 5 Next to Private IP, enter the IP address of the computer on your local network that you want to allow the incoming service to.
  • to check ip in your pc.. go to start menu click run.. type cmd and hit ok
  • in the black window enter ipconfig and hit enter, you will find the ip address
    Step 6 Choose Protocol Type - either TCP, UDP, or both. If you are not sure, select both.
    Step 7 Enter the port information next to Private Port and Public Port. The private and public ports are usually the same. The public port is the port seen from the WAN side, and the private port is the port being used by the application on the computer within your local network.
    Step 8 Enter the Schedule information.
    Step 9 Click Apply and then click Continue.
  • This would fix your problem..
    Nov 15, 2007 | D-Link Wireless Cable/DSL 802.11G Router...
    Xbox live
    You are better allowing your router to set the IP address automatically not doing it manally, i have no ports open other than for 'U Torrent' and can connect to live no problem
    Dec 16, 2006 | Siemens SpeedStream 6300 (33A6300001)...
    Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
    44 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
