Question about Nordic Track NordicTrack A.C.T. Elliptical
Turn off demo mode
Console won't shut off after use
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
THE CONSOLE ON MY PROFORM XP 185 U EXERCYCLE WILL NOT TURN OFF.
usually they will shut off after a few minutes. if not look in manual to see if it is in demo mode(stays on all the time)
Oct 06, 2014 | Exercise & Fitness
My kenwood kdu-u7053bt won't keep it's memeroy. Keep going to demo mode when I turn the car on.
go back to the stereo shop and make sure they connected the memory wire on the unit to a constant 12v source
Feb 03, 2013 | Kenwood Car Audio & Video
Nordictrack exp 1000X will only run on pre-programmed
When in Demo Mode, the console will go through a repeating lighting pattern. This mode will only become active when the treadmill is plugged in, the main on/off switch is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be turned off at any time.
ethod #1 to switch from the Demo Mode:
1.the STOP button while inserting the safety key tPress and hold o enter the user information mode.
2.Look in the Calories window. When Demo Mode is active, the letter 'd' will appear.
3.Press the SPEED DOWN button to toggle the mode on and off.
4.Once the mode is set as desired, remove the safety key.
Follow the steps and fix it.
God bless you
Jan 18, 2013 | Exercise & Fitness
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
appear.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack exp 1000 xl not shutting off
Your treadmill is in "Demonstration mode".
Here are the instructions to shut it off.
First you must enter "Information mode".
To select the information mode, hold down the Stop
button whilst inserting the key into the console. When
the information mode is selected, the following information
will be shown:
Total number ofhours that the treadmill has been used.
The Distance/Incline display will show the total number of miles.
An "E," for English miles, or an "M," for metric kilometres.
If a "d" appears in the display, the console is in the "demo" mode.
Press the Speed - button so the Heart Rate/Calories display is blank.
To exit the information mode, remove the key from the console.
Please be advised, when the safety key is removed THE TREADMILL IS NOT SHUT OFF, only the console is shut off. You must turn the machine off using the power switch in the front of the machine near the power cord, or I recommend purchasing a power bar with a power switch and turning the power off at the power bar.
Mar 01, 2011 | Nordic Track Exercise & Fitness
Hi - I just moved and when I hooked up my 2003 Panasonic SC-AK100, it stays in 'demo' mode and won't shut off completely...after showing "goodbye" and apparently shutting off, it comes back on...
http://www.retrevo.com/support/Panasonic-SC-AK100-manual/id/356ag917/t/2/
Page 12:
A demonstration of the display is shown if you have not set the clock.
You can reduce the power consumed in standby mode by turning it
off.
During standby mode
Hold down ['square icon'/-DEMO] until "NO DEMO" is displayed.
Every time you hold down the button:
NO DEMO (off)↔DEMO ON (on)
To show a demonstration of the display
Hold down ['square icon'/-DEMO] until "DEMO ON" is displayed.
Jan 16, 2011 | Panasonic SC-AK100 CD Shelf System
Demo mode on and system does not stay on
Try to put a cd in,this should kill the demo mode.
May 13, 2009 | Kenwood Sirius KDC-MP825 CD Player
PS3 Retail Demo Mode
In security settings press and hold select + square + L1 and L2
than enter 1 of these following codes depending on your version number
1.5x code: 5202
1.6x code: 7568
1.7x code: 0506
1.8x code: 7712 or 7259
and the ps3 will be unlocked from demo mode.
but be aware that this will only be for a couple of minutes.
so make sure you have the latest firmware the not demo one but the ordinary from the playstation site on a removable storage media
something like a memory stick or flash drive
so you can update immediately after unlocking you ps3! only this way you can completely unlock your system!!
May 02, 2008 | Sony Playstation 3 (PS3) Console
Nordic Track NordicTrack A.C.T. Elliptical Logo
206 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
