Question about Kenmore Refrigerators
253.5436940p Control panel diagram for model 253.5436940p
Require a wiring diagram to connect contol panel
With no brand/model it's impossible to answer. Try Google search for (brand/model) wiring diagram.
Jul 10, 2016 | Washing Machines
I need a wiring diagram for the control panel for GE dryer model number shear46ee1ww
It should be either folded up inside the control panel or pasted inside the dryer front panel
Nov 11, 2015 | GE Dryers
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Need kenmore electric dryer model 110.66662500 wiring diagram. will not heat
Should find the wiring diagram under or in behind the control panel accessed by removing the 2 screws holding the panel down either in the front lower or rear lower end caps . If you can't see any screw heads there may be removable covers on the end caps from top to bottom . On some newer models you can insert a putty knife under the end caps on the front and depress a clip on either side and the whole control panel lifts and lays back. Before any of that check your fuses at the panel 2-- 30 amp
Nov 04, 2010 | Kenmore Dryers
Control panel doesn't work
F7 indicates either a stuck key or the main control has failed. Try depressing each button one at a time checking for a stuck key. If each one retracts I would replace the main control this is more likely the problem. There easy to replace. If you enter your model # at www.appliancehelponline.com you can get diagrams and illustrations of your specific model.
May 27, 2010 | GE Profile JTP56 Electric Double Oven
How to re-connect the electrics on the control panel
This is not a valid model number, however, all appliances have a wiring diagram/schematic attached to the chassis or affixed to a door/access panels.
Aug 31, 2009 | Dishwashers
Dryer
Most wiring diagrams are located inside the control panel area
Jul 11, 2008 | Dryers
Refrigerators Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
