Question about Kenmore Washing Machines
Kenmore Combo Washer 110.88732796 drum way off
The drum seems to be way off line. Even when empty the drum is not lined up properly. Happened after I washed a load that got way off balance. I want to remove the top so I can look down inside and reposition it if possible but I can't remove the top. Can't find a service manual online to see how it's done.
  • 20 Answers
Just manually correct by over correcting (pushing)agitator in counter direction. Unless it is banging against cabinet side in next wash cycle there is no problem other then looks and will eventually correct itself in future loads cycles
Posted on May 22, 2009
Why is my washer making noise like the drum is out of line or something is stuck in the track
Is the pump running all the time
trying to remove the water?
Under the machine maybe a diagnostic
manual
You can remove the front cover on some
machines,probably have to tip it over to work on it
You need that service manual
Jul 15, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore 500 bangs when spinning
Sounds like the bearing in the drum has bust but shouldnt be too expensive to replace.
Nov 19, 2013 | Kenmore 24902 Top Load Washer
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore series 80 dryer . Drum does not spin, even when empty.
Good day,
If runs and heats, then the most probable cause is a broken belt.
Not hard to change. Below is a tutorial on how.
The Kenmore line is manufactured by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Dec 19, 2009 | Kenmore Dryers
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Water appears in drum hours after being emptied
could be several reasons...condinsation, if small amount of water moisture try leaving door ajar and see if evaporation takes care of it then you will know and it's possible that your water inlet valve has some "dirt" trapped in the seat and allowing water to seep into washer even though unit not calling for water
May 19, 2009 | Kenmore Washing Machines
Washer continuously filling/emptying
Your drain hose from the washer is in your household drain line too far, should not be any further in the drain line than 7 inches
Mar 23, 2009 | Washing Machines
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
179 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
