I need one (1) flywheel belt for my recorder TASCAM 3030
2 Suggested Answers
issy2
  • 460 Answers
SOURCE: replacing capstan and flywheel belts- tascam 244
Surely you can take it to any electronics repair shop and get it replaced, also they will tell u the necessary replacemnts to be done. All the best.
Thankyou...!!!
Posted on Feb 10, 2008
I require an image of the capstan flywheel drive motor assembly of a Tascam 424 MK1. Regards, Mike
The best reproduced manuals are at Stereomanuals.com as this is where I get mine from. Why do you need such a drawing? I will look as what I have here. The mechanical drawing might help and it might not. If they- whom ever fixed it lost parts they did you a dis-service. Now a spare unit will be needed to get parts from.
May 11, 2017 | Tascam Audio Players & Recorders
I have a Tascam 488 mk II that will rewind and fast forward, but will not Play or record. Does anyone know a solution to fix this problem?
Check too make sure that the tabs on the cassette itself are there if they are gone place a piece of tape over them, then try recording again. It may be a belt issue open the unit and see if all the belts are present cassettes usually have 2 or 3 separate belts one controlling the fast forward and rewind and another for record and play more than likely this is the issue, If so belts for these units are obsolete try searching science and surplus magazine catalog they carry a variety of large rubber band / belts you may get lucky and find one there good luck I hope this helps you
Mar 31, 2015 | Tascam 488 MKII Portastudio
On my tascam cc-222MKll it gets stuck reading opc
The door won't open might be a sign that there is a bad belt in the mechanism as the pickup may also be driven or positioned by the same belt- It may need to be looked at by a Technician.
Dec 20, 2012 | Tascam CC-222mkIII CD Player / Recorder
Tascam 238 Syncaset 8 track Pro recording deck needs new sensor belt. Looking for a belt kit for this unit. Problem has been diagnosed but the tech I've found to service it wants me to get the...
If he wants you to get parts then I would suggest you get a different Technician. Why would any Technician want to go to the trouble and risk of the customer getting the wrong belt.
You can get a set of belts from Marrs Communications for that model.
http://marrscommunications.com/tascam-cassette-kits
Jun 02, 2011 | Tascam Audio Players & Recorders
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam DA30 Mk1 drawer and noise problems
HI...
There are 2 belts in the mechanism that would need replacing.
I've fixed 2 of these.
There's a very small belt on the underside of the tape drive assembly
1.55 inch belt x 0.039
www.studiosoundelectronics.com # SBO1.55
Dont remember the other
Jan 21, 2009 | Tascam DA-30MKII
Replacing capstan and flywheel belts- tascam 244
Thankyou...!!!
Feb 05, 2008 | Audio Players & Recorders
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
53 people viewed this question
 Grubhead
Grubhead
