Question about Kensington Keyfolio Expert Android K39532us
Bluetooth connection issues with Kensington K39532US
Driver failure message indicated when trying to sync. - Yet identical model tablet and keyboard with identical driver works on another tablet.
myob247
  • 1342 Answers
SOURCE: Drivers for Kensington 64385 Wireless keyboard / mouse combo
You can get them HERE
Posted on May 28, 2008
SOURCE: wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
Posted on Jan 11, 2009
SOURCE: I obtained a used Kensington 64379 wireless keyboard. I plug the circular pad with USB cord into my PC. I can't get the keyboard to do anything, or even indicate it's connected.
Did you install the software first? Try plugging it in to another USB port.
Posted on May 29, 2009
dpct2600
  • 17 Answers
SOURCE: lost driver for my kensington pocket mouse model
Hi mdriskell,
I'm not sure if this will work for you but go to this site: http://us.kensington.com/html/1466.html#mw611 There is a download of "Kensington MouseWorks™ Software Version 6.11" which might be what you need to make your mouse work. If this does not work, I'll see what else I can find for you. According to the site, it does work with Windows Me. Just out of curiosity, why are you still using WinMe?
Good luck,
Dragon PC Training & Repair
Posted on Jan 08, 2010
MUKHTAR
  • 2017 Answers
SOURCE: My kensington k72271 mouse just stopped working a
after replacing the battery have you syncronize with the reciver sensor dongle .just press the conncet button on mouse it will work.
Posted on Jan 19, 2010
I have a samsung tablet and my kensington keyfolio pro 2 wirelee bluetooth keyboard... it connects to the tablet, is it supposed to?
Hi Lynnette,
Your Samsung Tablet will be on the same Router as the Kensington Keyfolio pro 2 wireless Bluetooth keyboard and would therefore expect it to connect to your Tablet.
Regards
Eric
Jan 07, 2017 | Samsung Computers & Internet
Kensington keyboard manual
Your model number isn't listed, but all published Kensington keyboard manuals are available at
http://www.kensington.com/manuals
My keyboard (model K39336) connected easily, so here's what I had to do. Ensure the Ipad Bluetooth is on in settings. Turn on the keyboard, and when you see a single blue light, press the connect button. The iPad will give you a four digit code to type in on the keyboard. When you type in this code, the iPad and keyboard become 'paired' and keyboard input is available whenever the keyboard is turned on.
Aug 18, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
Where do i find the keyboard passcode?
Typically when the keyboard is turned on, the device discovers it. Once the device discovers it, you should be able to press connect on the keyboard and the Bluetooth pairing request with the code should pop up on your device. Then you should be able to enter the code on the keyboard, press enter and connect.
May 27, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
The keyboard on my grandparent's tablet doesn't work. It's just one line. The keyboard e one installed in a black cis thase that came with the tablet. The rest of the lines work.
Try disconnecting the bluetooth connection in the Bluetooth menu and then re-sync the two. If this does not work I think the keyboard is got issues that cannot be fixed unless sent back to factory
May 24, 2014 | Kocaso M1066 Android 4.1 Dual Cameras 8GB...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Wireless keyboard will not connect
For non bluetooth you can synchronise the mouse and keyboard with laptop dongle by pressing synchronise button on bottom side of keyboard or mouse and also on the dongle.A steady green light indicates synchronisation. For bluetooth check regular bluetooth settings.
Jul 22, 2013 | Kensington Computers & Internet
Keyboard sync button flashes but will not link with ipad
my keyboard shows that it is connected to my iPad but I can't use my keypad it doesn't show up on the monitor
Jan 20, 2013 | Kensington KeyFolio Bluetooth Keyboard and...
I lost the passkey to my Kensington Keyfolio Pro 2 Universal Bluetooth Keyboard. Is there still a way for me to connect?
Enter 5 digits on the laptop or tablet and press enter, then quickly enter the same on the KeyFolioTM Pro 2 Universal and press enter. Will sync up fine.
Aug 26, 2012 | Kensington KeyFolio Pro 2 Universal...
How can you fix your bluetooth pin on the samsung galaxy?
It maybe connected by bluetooth, so i think it needs no password, Suggest you to contact Samsung ,they should be helpful. GOOD LUCK.
Android 4.0 Tablet PC
Jan 29, 2012 | Samsung Galaxy Tab Tablet PC
Kensington Keyfolio Expert Android K39532us Logo
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
