Question about HP Officejet 4620 Wireless Multifunction Printer - Wireless Printers
How to shut off the blue light flashes on the officejet 4620 printer
How do I fix a printer HP 4620 wireless that is not copying but can print from iPad or iPhone. The screen shows Now printing page 1 indefinitely. Thank you for your help.
H/P's are loaded with software glitches and driver short comings. You may need to remove the power cord for 2 minutes and then power up from scratch. After you do that power down your mobile devices as well. I mean completely shut them down so they need to reboot for a minute when they are turned back on. Do the printer first. This will cold boot your printer and make it available for fresh initialization. The mobile devices will update drivers if available. Good luck. And no it is not the same as turning the on/off button off and on.
Apr 28, 2015 | HP Officejet 4620 Wireless Multifunction...
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
HP Officejet 4620
Use a go/nogo tester to check the on switch. I suspect it needs replacing.
Mar 20, 2014 | HP Officejet 4620 Wireless Multifunction...
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
HP Officejet 4620 Wireless Multifunction Printer - Wireless Printers Logo
Seeker5211
Seeker5211
