Question about Canon CLC 1120 Color Copier
I have canon 1120 clc problem is error code 020 sub code 173 please solve this
Canon clc 1110 code e020 0173
Posted on Oct 21, 2011
  • 78 Answers
Sounds like you have a problem with magenta
The backup data on the CPU PCB is
faulty* or the initial settings have
not been made.
*Be sure to initialize the RAM of
the DC-CPU and enter the values
recorded on the service label.
Toner Concentration Fault
xx indicates the color of a developing
assembly.
xx=00: MCYBk in common
xx=01: M
xx=02; C
xx=03: Y
xx=04: Bk
The notations used herein means the
following:
SGNL: toner concentration signal
REF: concentration signal
DENS: developer concentration
inside developing assembly
SIGG: gain value for concentration
reference signal
PT-REF: concentration reference
signal for photosensitive drum
surface
PT-STG-D: reflection light intensity
surface
xx73 During copying sequence, the
level of PT-SIG-M/C/Y set
initially is '749' or more or
that of PT-SIG-K is '371' or
more because of an error in
the memory backup data.
Posted on Sep 13, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
E072 error CLC 800
i need a sub code like e072-002 or 003 and so on because it can be several things generally it has to do with yopur transfer drum any where that macvhine is way outdaTED AND THERE ARE VERY FEW THAT CAN SOLVE YOUR PROBLEM
Jun 04, 2008 | Canon CLC 1120 Color Copier
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Canon
This has to do with Potential Control - without a sub code I can't direct to a more specific direction. How many copies are on the drum?
Nov 07, 2007 | Canon CLC 1120 Color Copier
Canon 1120
I don't see where you've indicated the error code. Can't really help unless you describe more of the problem or the error code and any sub code displayed on the LCD display.
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
419 people viewed this question
old marine
old marine
