My Panasonic pt-51g54a projection tv has quit working. the picture got small and went to the center of the screen i have been able to shut it off for a while and turn it back on and it work but now the tubes will not come on at all there is a sound like the power is on but no picture. with the way it was acting i thought it might be the power convergence board but now i am not sure. could it be the flyback transformer?
  • mallen83 May 18, 2009
    do you have the part # for the flyback transformer?
  • mallen83 May 19, 2009
    thanks for the help
    Brigadier General:
  • 8,619 Answers
Hi
The first thing that should be done is to replace the convergence ICs (STK392-110). Then you need to check all resistors if they are fine , also check for any cold solder joints. Please contact Panasonic for the part nos as it is always recommended to use original parts.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 19, 2009
  • Rylee Smith
    Rylee Smith May 19, 2009
    You can also call panasonic by clicking on this link.
    Thanks
    Rylee
    Brigadier General:
  • 3,614 Answers
The problem with no picture, but working sound, this is a loss of the high voltage system. This is almost always failure of the high voltage auto transformer called the flyback and/or the HOT (horizontal output transistor) - which work together in producing the horizontal scan of the raster system and the high voltage to produce the raster upon which the video picture is modulated.
The failure could very well be from HIGH temperature involved with the storage of the tv set.
Let me know for any clarifications.
Posted on May 18, 2009
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47wx53 just shut off
Your convergence ICs have failed. Thats what causes the led to blink three times. The PT53WX53 convergence repair kit from www.tvrepairworld.com will usually repair that issue. The kit also contains the CD with detailed repair instructions.
Apr 01, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Picture went out and now there is only aline of some color in the center of picture frame
This is failure of convergence out ICs in TV that needs to be replaced.
Let me know if you want to repair TV by yourself or call local tv tech for fix.
Thanks.
Nov 05, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic Projection TV
If you are using your TV's internal speakers, then you have a loose connection inside your TV more than likely on your audio output IC. Re solder all connections on your audio output IC's. To locate your IC, trace your speaker wire back to the circuit board.
Feb 23, 2008 | Televison & Video
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
