Question about Maytag MSD2454G Side by Side Refrigerator
Maytag refrigerator MSD2454GRW--How do I access the drip panel?
I lost power to my refrigerator while I was on vacation and everything spoiled. Now I have a horrible odor coming from below the fridge, but can't figure out how to remove the front grate (without removing the doors) to clean the drip panel. Thanks
  • 66 Answers
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Posted on Feb 07, 2008
SOURCE: Maytag MSD3453GRW leaking and not running
i think it might be **** get it a diare or something
Posted on Jun 18, 2008
SOURCE: maytag refrigerator MSD2454GRW shelf removal
The above answer is only HALF right. The blue clips have to be removed to lift the shelf up and pull it toward you.
To remove the clips:
1. Get a screw driver or something to get behind the clip.
2. Slide it behind the clip and slowly pry it toward you.
3. Repeat for the clip on the other side.
4. Do the above; lift the shelf slightly and pull it toward yourself.
Posted on Mar 02, 2009
SOURCE: On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Posted on Apr 04, 2009
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
Cannot get the ice bin out of my Maytag msd2454grw
Not sure about Maytag but I would have expected it to just lift at the front and slide out on its runners? Check the owners book or ask a Maytag Dealer to assist
Nov 20, 2016 | Maytag Refrigerators
How do I find the drip pan on a Maytag MFF2558VEW2?
This is an Amana built (part of Whirlpool, like Maytag) unit and it is under the unit. Pull the refrigerator away from the wall and remove the service panel cover - lower panel near the floor - and you should see it. This is a tight space and can be challenging to access.
Sep 12, 2014 | Refrigerators
Fridge Maytag model msd2454GRW - Refrigerator not cooling, alot of moisture buildup in fridge. What is the symptoms of the defrost timer sticking on.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Maytag Refrigerators
Freezer is leeking inside. MSD2454GRW. 2003 Maytag.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator has spoiled meat odor. Can't find
drip tray is under unit remove toekick and check if pan heater is connected
Nov 06, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Jun 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
332 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
