Question about Fellowes DM12C Shredder
The green light on the Fellowes shredder will not come on when the switch is turned to the "I" position. It works in the "R" position.
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
  • 255 Answers
SOURCE: fellowes shredder only works in reverse
The unit sits on its own custom waist basket. In the unit is a micro switch that must be clicked by the seating of the unit on top of this waist basket. If the micro switch isn't activated, forward won't work. Check this. Short of this, the microprocessor that runs the diodes might not be working. (The diodes, one transmitter, one receiver, tell the machine the presence of a piece of paper in the slot.)
Posted on Nov 26, 2009
SOURCE: OD700C Fellowes Shredder blades don't turn
There is a screw hidden under one of the stick on labels. Remove that and the top comes just fine. I got it torn apart, completely cleaned of debris but the rollers still don't turn. I noticed an electrical arc when the switch is pressed so the unit is toast.
Posted on Mar 05, 2010
Testimonial: "Thanks. I found the hidden screw and was able to get inside. I know what's wrong with it now and hope to get it fixed. "
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
Mar 05, 2014 | Fellowes Office Equipment & Supplies
Red and green light is on but it wont shred
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Nov 13, 2012 | Fellowes Powershred PS-60 Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
hth,
razors
Apr 14, 2009 | Fellowes PS60C-2 Shredder
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Oct 16, 2007 | Fellowes PS70-2CD Shredder
Fellowes DM12C Shredder Logo
82 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
